[EBGLT]
Hey guys will EA-ED Wagon Interior fit into EA-ED sedan? Im just talking about front and rear seats!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
Gunna girlie-man
the fronts are a straight swap, but the rears might be more difficult. where are the brackets on the backrest? in a sedan it bolts on a verticle face, but im pretty sre the wagon bolts to a horizontal face
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
TL40 Wagon?
rear wagon seats are different. could be done but bracket work and so on to be done.
You win again, gravity!!!
I tried putting an ED sedan interior into an EA wagon, front seats are fine, but the rear seat is different... brackets and side bolsters are totally different... I considered modifying it to fit, but I doubt it would have worked...
1994 ED Ghia SOON TO BE A TRACK CAR
[EBGLT]
Cant you just change the brackets like remove the old brackets of the interior your taking out and put the onto the interior your putting in?
Posts: n/a
you need to drill the sedan brackets off the original seat and remove the old wagon brackets. then you need to get a bolt with a short thread and the same thickness as the bracket holes and bolt the sedan brackets onto the wagon seat in the correct positions. also use a nyloc nut so they dont become loose.
ive done it twice so it can be done. bolsters also need to have the material removed and put onto the sedan bolsters. ive used cable ties to re-attach the material. bottem clips straight in. bit of work but its doable. |
Posts: n/a
would this be the same with putt nf fairlane interior into eb wagon i know the front seats go with minor adjusting
OK so Ive run into this problem. Whats the best way to drill the bolts out? Me and braden were at it forever drilling one and didnt seem to get anywhere :S also is it much work in fiddling with the bolsters?
#9 | |||
Posts: n/a
#10 | |||
Steve
Silver PJ Ranger XLT ...with goodies... |
