Old 09-01-2007, 02:18 PM   #1
get_an_ea_today
Festoon This!!!
Default 4L Computers (urgent)
Hey guys would a ef manual computer work a eb 2 engine or any other e-series 4L engines?
also would a 3.9 manual computer work a eb 2 engine?
any help would be much appreciated
cheers
matt
get_an_ea_today is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 02:23 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
EA,EB,ED and EL are 60 pin
EF and AU are 106 pin
So the answer is basically NO.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 02:26 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
EB2 if it is smartlock so you need a smartlock computer, I don't think a 3.9L came with smartlock.
Old 09-01-2007, 02:31 PM   #4
get_an_ea_today
Festoon This!!!
So the ef computer wont work at all ok
and the ea computer wont work because of smartlock? do you need smartlock? is there anyway around it?
the reason im asking is because my mech is out getting a new engine and he suggested getting another 3.9 engine so i dont have to change the computer. but i would rather a newer engine if im going to all the trouble of changing engines.
and the reason for changing the engine is because the bottom guide on the timing chain is broken and he said your better off getting a new engine the fixing the one i have. this is after i paid him $300 for replacing the timing chain :(
Old 09-01-2007, 02:43 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
Oh ok i get you now
You can run any engine you want from EA to AU (au is a little bit of work) and use the 3.9L computer
I run an EA auto 3 speed ecu, 4speed trans controller and an EF motor in my EA series 1.
Old 09-01-2007, 02:48 PM   #6
get_an_ea_today
Festoon This!!!
oh great
so i can keep my 3.9 manual multi point computer and run any e-series 6 cylinder engines and it should be ok?
Old 09-01-2007, 02:49 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
Yes, thats correct, you may choose to go serpentine if selecting an ef/el motor to drop in as well, plenty of threads on this subject if you do a search.
Old 09-01-2007, 02:55 PM   #8
get_an_ea_today
Festoon This!!!
Great! i can stop stressing now lol
is there any benefits for doing that conversion?
Old 09-01-2007, 09:22 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
Serpentine gives you 1 belt that self tensions, a 110amp alternator, you would need thermos fans, other then that not much.
Old 09-01-2007, 10:36 PM   #10
fmc351
let it burn
May be worth clarifying, if your going to run an EL motor for example on the 3.9 ECU, you need to use the EA sensors, and inlet manifold.
fmc351 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 10:07 AM   #11
EA2BA
PM me if you want
EA2BA's Avatar
You can use the BBM manifold (I have) just leave the runner switching disconnected and you make the same power as you would with an EA manifold, and I did plug all my EA sesnors in just to be sure it would all work.
Old 10-01-2007, 02:22 PM   #12
get_an_ea_today
Festoon This!!!
Well heres the scoop, i didnt need to replace the engine thank god, some bearing was completely stuffed and the mech thought the cause of the rattlerling was the timing chain but he has fixed that and changed my water pump cause it was very corroded so all up it was $420 to fix. (much better then $1000 for a whole new engine)
But with the Serpentine conversion can i do that on my 3.9? with the ef/el intake thats the BBM manifold isnt it? Would i need to change anything else when changing over the parts? like ecu ect
Old 11-01-2007, 09:46 AM   #13
EA2BA
PM me if you want
EA2BA's Avatar
I tried a serpentine with my 3.9L the crank is different, I ended up with alot of grinding to get it all set up then 30seconds after starting my engine died, would not start and could shoot flames out the throttle body, put an EF motor in to fix that problem.
So try it at your own risk.
The BBM can still be fitted to an EA motor though, gives you more access to the coil and dizzy, otherwise no big deal.
Old 11-01-2007, 12:37 PM   #14
get_an_ea_today
Festoon This!!!
Well from your story im not going to do that lol!
great so the BBM will just go on no problems so i would need to get a ef/el airbox? and would i get anymore power doing that conversion?
Old 12-01-2007, 01:02 AM   #15
fmc351
let it burn
Like you need more room in an EA, the EA manifold design is a marvel of mechanical science.
It would almost be easier if the EA dissy was in the sump.
Old 12-01-2007, 09:41 AM   #16
EA2BA
PM me if you want
EA2BA's Avatar
Agree with that, I think it was designed by a blind russian contorsionist, it is certainly not a maintenance friendly bit of engineering.
Old 12-01-2007, 09:51 AM   #17
steven95falc
Just keep in mind people if you do the serpentine belt conversion with a eb style inlet manifold your up for a new belt tensioner and there not cheap.
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 01:33 AM   #18
fmc351
let it burn
It would be OK if they moved the oil filter, and the crossmember, and the dumb front square bar, and the water pipe, the stupid bracket to hold said manifold, and the AC compressor. I could live with the rest.
