75th anniversary
what would ea spack wheels look on an eb gl (the ones i could get are in good condition)
If they are in good condition they look allright, maybe even chrome them up to be different...
75th anniversary
thanx for the reply
LZ 2016 Focus RS in shadow black |
Keep us posted with what you end up doing with the wheels mate :-)
need more boost
I'm not a fan of snowflakes at all. Black stockies would look better, or even hubcaps, and I'm not keen on those either. Actually, the only "rim" I hate more on e-series than snowflakes are those "marie biscuit" hubcaps...
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
![]() Join Date: Dec 2004
You might also want to consider XF snowflakes, which aren't dull grey like the EA ones (their design is identical though)
#7 | |||
Parts bin special
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
Yeah IMO snowflakes only look good one either XE or XF Ghia's. Id go hub caps before them.
Get some EF/L 15inch stokies black.
Car has to be dumped no matter what rim's you go for or it will look sh|t. |
they are a pain in the but to clean i got em on mine can,t wait til i can get some new 1,s
HTFU!!!! |
Snowflakes rock! Here's a recent picture of my car with them, I should have put the front bar back on for the pic :P
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH Last edited by needfordspeed; 06-06-2013 at 06:48 PM. |
let it burn
Mine hold the tyres quite well, never had one fly off yet. :nutsycuck
#13 | |||
Parts bin special
#14 | |||
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#15 | ||
best looking car on snowflakes ever Gilli.
#16 | ||
this should be a rule every Falco'driver follows...
1. Black stockies on the rear (ONLY) with some sort of non black rim up front, even if its hub caps or 15" Snow flakes ![]()
93' EB II XR6 factory manual Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02: |
#17 | |||
I dont like getting pulled over. Gilly- Get some tyer shine on them man and screw front bar's when u got a massive tranny kooler to show off.:P Dez- Stokies over turbo blade'sany day mate.;) |
