01-12-2006, 01:25 PM | #1 | ||
quick question, will a v8 radiator bolt straight into 6 engine bay or are some modificatations required. is this a worthwhile change over?
01-12-2006, 01:31 PM | #2 | ||
yes, it bolts straight in. get an ED XR8 Sprint radiator. i have had one for 2 years
Powered by Rollin Motorsport Turbo Barra ED 4L
01-12-2006, 02:15 PM | #3 | ||
awesome. Do you happen to have the part number for the sprint radiator? and did you buy it from ford? the reason i ask, is i work at coventrys, and can get hold of a v8 radiator cheaper than i can get it through ford
01-12-2006, 02:19 PM | #4 | |||
E-Series Member
14.66@94.37mph - Calder Park, 24/11/06 (N/A) |
01-12-2006, 03:15 PM | #5 | ||
Virtuous Bogan (TM)
I would have thought there would be a V8 version, and a I6. A sprint didn't have "that" much more power.
01-12-2006, 03:18 PM | #6 | ||
OzECruisers Treasurer
V8 Version is 302
01-12-2006, 03:46 PM | #7 | |||
01-12-2006, 04:20 PM | #8 | ||
Virtuous Bogan (TM)
yeap when I got mine done I had a choice of a $170 version or a $270. I took the later, one thing IMO you dont risk on a I6 is the cooling system.
01-12-2006, 04:36 PM | #9 | ||
AU II XR8
my engine overheats with my aircon running, but runs normal with it of. its an 88 EA. did the EA II have a radiator change? also would the the V8 radiator benifit the engine with the aircon running?
01-12-2006, 06:56 PM | #10 | ||
Virtuous Bogan (TM)
Hmm not sure about that.
What I do know is that my EL is a million times better at handling the heat that my previous EA's. Even with air con on full its never gone past half way.
01-12-2006, 07:26 PM | #11 | ||
According to Aus Muscle Car mag, the EB XR6 has a V8 radiator too.
I am assuming this a 3 row rad, as opposed to a 2 row rad in the standard 6. Anyone cornfirm this? |
01-12-2006, 08:27 PM | #12 | ||
I've had a genuine EB I6 and genuine V8 radiator side by side, and it appears the only difference between them is the number of fins per inch - the V8 one has more, which means better cooling, and it does make a difference.
According to the prices I got from ford the V8 one is a little cheaper as well. Go figure. NeedaXYGT - I'd be looking at the cooling system as a whole rather than just the radiator - get a new thermostat, pull out the radiator and flush it, clean all the junk out from between the radiator and the condensor, and check the clutch fan is still fairly stiff to move by hand. These cars didn't overheat new, which means that if they start to overheat it's from a worn or malfunctioning part, rather than ford just not doing their homework. |
02-12-2006, 01:41 AM | #13 | ||
well, i am only quoting what i was told from the ford spares dude... he said it was an xr8 sprint one... i am sure they are the same, but thats what i was told.
02-12-2006, 05:00 PM | #14 | |||
AU II XR8
02-12-2006, 10:55 PM | #15 | ||
The one and only
Since when is there a difference between the V8 and I6 radiator?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
03-12-2006, 02:12 AM | #16 | ||
Since about 3 years back - I got ford spare parts to bring a brand new factory ford V8 and an I6 radiator, and I compared them side by side, and they are the same, except the V8 one has more fins per inch than the I6 one, and last I checked, is slightly cheaper.
03-12-2006, 05:06 PM | #17 | ||
would the EF V8 rad fit aswell to a I6 rad supports?
03-12-2006, 05:27 PM | #18 | |||
13-12-2006, 08:00 PM | #19 | ||
So is say a el v8 radiator a bettter option than an ED v8 radiator?
and another quick question, are the hoses used the same? or do you need to make up custom hoses to go from radiator to engine? |
13-12-2006, 08:58 PM | #20 | ||
if you want a decent radiator get this one, three core, copper and brass tanks
http://cgi.ebay.com.au/FORD-FALCON-E...QQcmdZViewItem
13-12-2006, 09:01 PM | #21 | ||
ea to ed have larger bottom hose outlets. ef and el have smaller bottom hose outlets...
13-12-2006, 09:19 PM | #22 | ||
nah i mean are the top and bottom hoses the same for the 6 and 8? (on the ED)
and i need it to be manual compatible aswell |
13-12-2006, 09:22 PM | #23 | ||
yea, top is the same
doesnt matter if you get an auto radiator... both fit
13-12-2006, 09:29 PM | #24 | ||
likes falcon's
get thermo fans guys....lol
my old ladies car had 4 leaks in the radiator and never overheated (standard battered ea radiator). beat that!
www.carhubsales.com.au |
13-12-2006, 09:35 PM | #25 | ||
yeah i am getting thermo fans, just thought id get the v8 radiator to match to make sure its really kepy cool. soooooooooooo there
14-12-2006, 01:06 AM | #26 | ||
AU II XR8
i was considering doing this as my car was over heating a little with the I6 radiator. took it to a radiator specialist and the result was that is was 50% blocked.
