Old 22-11-2006, 05:30 PM   #1
Auuteage
Default A second 12V source ?
The cig lighter is one...
Say I need another 12V source? Where/how could one achieve this ? thanks.
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 05:32 PM   #2
smally289
growing up is optional
smally289's Avatar
Direct from the battery, through either a fuse or circuit breaker, depending on what you are running off it.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 05:37 PM   #3
Orbit
Resident Nyctophobic!!
Orbit's Avatar
run a line from the battery through the firewall with a switch inline and a circuit breaker or fuse like smally said.
on the drivers side is the easiest route as teh batter is on that side as is a hole you can thread it through.
Orbits secret to life: Eat less, move more!
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 05:51 PM   #4
jones_aus
jones_aus's Avatar
easy temp way is to get a double adapter from any auto store
jones_aus is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 06:00 PM   #5
JoesAu
JoesAu's Avatar
or triple adapter and hide it like i have done.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 06:34 PM   #6
Auuteage
triple adapter? Got any more info? ta.
Old 22-11-2006, 06:40 PM   #7
smiley
be careful with adapters, if your drawing too much power through the cigarette lighter, then you'll blow its fuse.
Ice Mint Silver BA 02 XT
Typhoon airbox/snorkel/lower duct
K&N panel filter
2.5" Redback, high flow cat, Pacemaker headers
178.3rwkw
15.18 @ 95.72 MPH
smiley is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 06:47 PM   #8
JoesAu
JoesAu's Avatar
its rated to 120 volts the adapter, like your ever gonna get close to that. im running 2 led sticks(30cm long) lights of it and one small neon. Got it from supercheap auto. 10-15 buks i think.
Old 22-11-2006, 06:54 PM   #9
poolkeeper
Its Resonating!
poolkeeper's Avatar
Its pretty much a power board, but for your car...
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 07:19 PM   #10
Orbit
Orbit's Avatar
not the volts you have to worry about....it's the amount of amps drawn.
cigarette lighter fuse is only 10amps IIRC
Old 22-11-2006, 07:20 PM   #11
Auuteage
Super cheap auto have that sort of thing ? Where do you get them ?
Old 22-11-2006, 08:01 PM   #12
poolkeeper
Its Resonating!
poolkeeper's Avatar
Yeah supercheap, repco etc have them. Even my local k-mart...
Old 22-11-2006, 08:02 PM   #13
Auuteage
ok thanks for that :0)
Old 22-11-2006, 08:16 PM   #14
jones_aus
jones_aus's Avatar
ive rewired my cig lighter 12v to a 3 plug adapter in the centre console. cig lighter doesnt work anymore but im not a smoker so it doesnt bother me
Old 22-11-2006, 08:25 PM   #15
JC
Miami Pilot
JC's Avatar
I run 2 cigarette lighters and the DVD screens off the Amp circuit - it's 30Amps.
Ford Performance Club ACT
Old 22-11-2006, 09:41 PM   #16
AUXRVIII
The mobile phone power plug located next to the body module is a good source of power.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 09:52 PM   #17
TwistedEL
TwistedEL's Avatar
There is also constant power on the bottom right hand interior fuse
I wired automatic window ups through it
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 10:10 PM   #18
smiley
thats the adaptor's own voltage rating, but if the current being drawn by the load is too much, it will blow the ciggarette fuse, all will be good as long as your sure what you will be using won't use too much current. If your neons are using lets say 2.5 amps, hook another 2 neons up and it'l blow.
K&N panel filter
178.3rwkw
15.18 @ 95.72 MPH
Old 23-11-2006, 12:25 AM   #19
JC
Miami Pilot
JC's Avatar
Is that fuse # 21? If so, that's your airbag fuse. oops!
Old 23-11-2006, 08:24 AM   #20
Mechan1k
Mechan1k's Avatar
Fuse #21 is blank in my book (no fuse in it) .. unless it is a passenger side airbag (which i don't have anyway).
Old 23-11-2006, 12:37 PM   #21
TwistedEL
TwistedEL's Avatar
It's not the airbag fuse I think it was the satnav fuse (which obviously most of us don't have) but I'm not sure, I'd have to take a look-see tonight. It was definitely not connected to anything cause I had to hook it up through the loom (I have dual airbags).
Old 23-11-2006, 10:07 PM   #22
GlennBA
GlennBA's Avatar
There used to be an option for a second power source on AU's. Heres where it goes.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
