Old 16-10-2006, 01:57 AM   #1
misstx3
Arrow Tx3 Turbo.. Can Any1 Help A Gal Out?
Hey all, I have just recently bought a 92 kh2 4wd tx3 turbo. I have had a few probs..If anyone could lend there expertise?? :
Q1- When my car reaches a certain rev it beeps and cuts out.. Are these cars installed with some kind of rev limiter??
Q2- Just the past day it feels as though when my car is hitting boost that there is no power.. Does anyone know why this would be happening?? :
misstx3 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 07:48 AM   #2
AUIIForte
At what rev count does it beep and cut out at? And for your second questions, make sure that theres still a turbo in the car, maybe the previous owner took it out?
AUIIForte is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 08:26 AM   #3
dansedgli
dansedgli's Avatar
The piping may be heat soaked causing the lack of power on boost. This used to happen to me on hot days after sitting in traffic for a while.
Im not sure on your other problem though.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 12:15 PM   #4
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
sounds like your hitting the boost cut itll hit in the higher gears sooner as the car comes onto load. Do you have a boost gauge? if you do you mighrt find your up around the 14psi mark at full load. check all your wastegate plumbing. as for the lack of power it could be anything from boost fluctuations to flat tyres. What are you using to control boost?? and what mods does the car have?
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 06:53 PM   #5
VippiN
What a performer!
VippiN's Avatar
Q1 - You're hitting fuel cut. Your boost is up too much and the ECU is saying no thanks.
Q2- Could be a million different things.. Don't know where to start with limited information provided.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 06:57 PM   #6
misstx3
I haven't really taken much notice at exactly how many revs it cuts out at.. I think it may be just over 3 but i will check that out.. It does only happen in 4th and 5th gears. I do have a boost gauge but Seeing as I have only had the car a few weeks I have been taking it easy until i get it a good service, proper oil etc.. and also the cut off thing freaks me out a little cause i was unsure of what it did exactly that I have been taking it easy. The hardest I have driven it so far (not full potential) hit bout 11psi. No mods really.. Only a blow off vaulve. Everything else is pretty much stock. I don't know very much about the tx3 turbo.. maybe should have done my homework a little better ;-) I am used to my old vl turbo..
Old 16-10-2006, 06:59 PM   #7
misstx3
I think i'd realise the turbo missing!!
Old 16-10-2006, 07:05 PM   #8
misstx3
Not exactly sure whats going on with the cut off thing? If it beeps twice the boost light will start flashing. As for the lack of power?? It just feels as though the car is revving out but not going anywhere? It has just started happening the past day or so. As well as I will be driving and as I slow down or change gear the car will just turn off and the ignition lights will come up? So many problems already... Why do i bother?? lol
Old 16-10-2006, 07:37 PM   #9
9lives
9lives's Avatar
i would have kept the vl but hey thats me...
maybe the stock computer is hitting the boost cut off and thats why your loosing power as boost comes on.
You must be young and stupid to grow old and wise....
9lives is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2006, 07:39 PM   #10
9lives
9lives's Avatar
oh and if its just turning off check all your plumbing hose clamps etc sounds like your loosing vacuum via a loose intake pipe similar causing it to stall
Old 16-10-2006, 07:43 PM   #11
It'sTheVibe
It'sTheVibe's Avatar
Sounds like a slipping clutch..
It'sTheVibe is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2006, 08:01 PM   #12
misstx3
I know.. Wanted something smaller though.. ;-)
Old 26-10-2006, 12:54 PM   #13
It'sTheVibe
misstx3
Any luck with resolving these problems????
Old 08-11-2006, 06:48 PM   #14
TheKeTx3
Tx32be
I agree with Vippin i reckon you are hitting the fuel cut off .
TheKeTx3 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2006, 01:20 PM   #15
sintx3
But why the rum
sintx3's Avatar
Dont hate the car yet when u get it running properly you will love it its just allot of people that own these cars are cheap ***** and do dodgy things to get more power out of them not thinking of the concequences.
But ur first problem definatly seems like fuel cut try disconnecting the boost controller u have either bleed valve or electronic get a joiner piece to put the normal hoses back together and see how u go on stock boost they have 8psi stock cos if the cars running too much boost without a decent intercooler u could be getting allot of heat soak making it feel powerless.
1997 LS Focus XR5 turbo
sintx3 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2006, 10:11 PM   #16
ReVd_uP
ReVd_uP's Avatar
Q2- sounds like it could be an obvious solution but i had the exact problem on my brothers tx3 which is my old car, turned out just to be the ignition leads.... give that a try
ReVd_uP is offline   Reply With Quote Multi-Quote with this Post
