Old 15-11-2010, 11:56 PM   #1
DolphinJames
Default ICC unit playing up after reconnecting battery.
First ever thread anyway, I have just recently disconnected the battery (neg- first off, last on), and when I started the car 2 days later only the trip modes and aircon temp settings were showing. No stereo displays or fan and aircon settings displays either. The radio and CD player now do not work. I have a 2005 BA Fairmont with prestige ICC unit. would appreciate it if someone could advise me on what the .... has happened. Excuse the nerves it is my first time.
DolphinJames is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 01:08 AM   #2
1TUFFUTE
1TUFFUTE's Avatar
omg what r you doin..why r you posting here and talking like that......JUST KIDDIN COULDNT HELP MYSELF. sorry cant help im sure someone will know soon.
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 12:19 PM   #3
TheInterceptor
Cruising...
TheInterceptor's Avatar
Ouch thats harsh tuffute!
Ok, maybe theres a lose connection somwhere or somthing has fried?
Slapping the cabling back on the terminal = sudden dump of power....umm yeh if sombody who has messed around with b series icc's can clear this up before i make it sound like he's killed the car when it could be somthing simple!
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 12:28 PM   #4
csv8
csv8's Avatar
Being serious, this happened with my BF MK2..You have to get the ECU reset by Ford.
It cost me $235 for battery and ECU reset
CSGhia
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 12:32 PM   #5
Mr Brooksy
Youth worker
Mr Brooksy's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Numerous helpful how-to's and sound advice!
Did you check the fuses? I'd start there... then get someone to plug it in and see if there is an error code... Ford will do that.
2007 FPV F6 Typhoon BFII, Neo. Build Number 325
2011 SZ Territory
Old Futura thread:
Brooksy's Ex Build
Mr Brooksy is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 02:12 PM   #6
TheInterceptor
Cruising...
Whoa, now this is why i like older cars. Id be going troppo if this happens every time the batttery is disconnected.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
Old 16-11-2010, 05:02 PM   #7
Dr Smith
Don't be nervous...it might be worth giving one of the site sponsors here a call, http://www.aslautomedia.com/ they specialise in all things related to the Falcon ICC's. As mentioned have you checked the fuses. This might not work however if they are ok, maybe pull them out, turn the ignition on then off and refit them and see if they power up. Can't say it will work, although it does help with troublesome Bluetooth module on the FG ( I know you have a BA).
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 10:46 PM   #8
DolphinJames
Firstly, thanks everyone for your help and support. I have found the problem and I hope this will help others. All I did was push and hold the volume nob in untill the display reappeared.
