Old 08-01-2009, 09:51 PM   #1
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Default electric seat dead
the electric seat in my lane has stopped working, i press the switch it does nothing.
what should i check? it's gotta be a fuse or something
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2009, 09:15 PM   #2
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
has anyone got a gregorys for fairlane or fairmont ghia that could check for me please?
BA MK2 XR6T
Old 09-01-2009, 09:34 PM   #3
6 way or 10 way adjustable? In any event there are fuses and a circuit breaker in the fuse box. The ciecuit breaker can be reser by pushing a paper clip end into the hole on the base.
Old 09-01-2009, 09:45 PM   #4
ronwest
All Bran = Regular Member
Also, check the connectors under the seat.
Old 10-01-2009, 01:49 PM   #5
Dauphin
Irregular member
Dauphin's Avatar
According to the manual, it's fuse (circuit breaker) #22 which is the top, second from the right in the dash fuse box. This also does the windows and sunroof so I doubt it's that if the windows are working?
#23 which is to its right does the memory seat function.
Old 10-01-2009, 03:37 PM   #6
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
6 way adjustable seat.
connectors under the seat are fine.
I had some problems with the power window circuit breaker
http://www.fordforums.com.au/showthread.php?t=11244009
the seat stopped working at the same time,
the windows are working now and the buzzing hasn't happened again but the seat remains inactive.
BA MK2 XR6T
Old 11-01-2009, 06:48 PM   #7
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
after removing the p/w circuit breaker and putting it back in the seat functions came back so the problem is still relating to the p/w
BA MK2 XR6T
Old 15-01-2009, 11:42 AM   #8
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
this morning when i plugged in the p/w circuit breaker the relay below it started buzzing
and smoke started pouring out of the power plug for the seat.
great start to the morning, hopefully the problem is the seat and i can just leave it unplugged
BA MK2 XR6T
Old 15-01-2009, 02:58 PM   #9
Dauphin
Irregular member
Dauphin's Avatar
Doesn't sound too good, hope you can get it sorted out. Let us know of the outcome.
Have you done some power tests or something to make sure it's getting the right power, so you can isolate it to the motor?
Old 30-01-2020, 11:21 PM   #10
Typhoon lee_ste
Default Re: electric seat dead
Hi did anyone resolve the seat issue? Mine just set itself at its highest and I can’t get in the car:((( my knees are round my ears.
Typhoon lee_ste is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2020, 04:55 PM   #11
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Can you take it out and manually wind it down?
Old 03-02-2020, 05:39 PM   #12
Typhoon lee_ste
Uncle ken,manually wind it down? I’ve got the seat out and was considering putting power to the motor to see if I can move it.The seats are bolted through a pivoting hinge so maybe just fold them down.and reinstall.
Old 03-02-2020, 09:30 PM   #13
Typhoon lee_ste
Anyone know what the spare white plug is for under my Ba GT seat? Seats are not in a GT but they are in a BA.Tried to manually wind the seats down but they are stuck solid:( Seatbelt warning works but no adjustment so Next I’ll try the fuse.
File Type: jpeg F49A6FDA-7A09-4586-AD04-B1C1316E5EA6.jpeg (112.0 KB, 5 views)
