Old 29-03-2020, 08:52 PM   #1
FordCapri72
Talking Wanted Ford 1972 gear linkage cable for an 4cyl auto
Hi guys and girls I was after a gear linkage cable for a 1972 ford capri auto and if anyone has one lying around that they don’t want anymore and it’s no seized or knows someone that would sell it that would be much appreciated as mine is seized and broken, I am located in western Sydney and can travel to pick up, I have attached my broken one for a reference and
Thanks for viewing my add 👌
File Type: jpeg DDE6F2C4-8404-40EA-8BD8-2936985AB911.jpeg (79.9 KB, 11 views)
FordCapri72 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2020, 09:12 PM   #2
GTLEGEND
Default Re: Wanted Ford 1972 gear linkage cable for an 4cyl auto
Try these guys:
http://www.yesterford.com/
or
http://www.karcraft.com.au/
Old 29-03-2020, 10:21 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Hey bud, whats the length between these points on the cable:
Basically the length from where it mounts on a bracket to where it goes to the end of the threaded rod going into the fittings on the end.
You may be able to use a hydraulic valve control cable if you can mcgyver something up, this will be the cheapest option:
https://www.flexibledrive.com.au/sta...tcvaptckgv.pdf
This place above has a handy little guide on choosing hydraulic valve control cables.
Otherwise cable manufacturers such as Flexible Drive above or Control Connections could manufacture from sample as a custom job reusing parts from your busted sample there - but $$$.
Old 29-03-2020, 10:42 PM   #4
GTLEGEND
There is also these places:
http://www.generalautocables.com.au/
https://www.retrospares.com.au/auto-...?rf=va&va=2073
https://www.attspeedautoinstruments.com/services.html
Old 30-03-2020, 09:37 AM   #5
falconhell74
falconhell74's Avatar
Flexidrive industries will make you a new one if they don't have one in stock , just take your old one in or if you cant then measure it and give them the specs
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
