turbo kid
hi, ive just gotten my el falcon today and the only thing not working is the brake lights. ive checked fuses, light bulbs, ground and some of wiering which all worked the way they were supposed to. anyone got any ideas on why it doesnt work? oh and if you have spare time, how do i get the antenna to come out of the front guard?
all help apreciated. ![]() |
Gunna girlie-man
do your parking lights come on with the headlights??
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
Last warning
brake light switch on the brake pedal has most likely failed.
its fairly common for them to die after a while, not a hard job to change, infact when mine first died, ford changed mine for free. (+ the price of the switch itself)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Shoot.
Like suggested, if your fuses are fine and the parker lights turn on without blowing the fuse then it's most likely the brake switch.
20V Turbo |
turbo kid
ok, thanks. the lights do come on when parkers are on.
ill pop down to adrian brian ford on monday morning and get it changed. appreciate it guys ![]() |
No, no, no. Don't go to your ford dealer. I bought my first brake switch from them and it was $50 odd bucks. Go to Repco, $9.60. Takes 2mins to change and req no tools. Just push your seat back and look at the brake pedal. Find the wiring (L plug) and disconnect. Pull out the spring pin (it will be tough but try and rotate it 90 degress laterally). The switch then slides off. Watch carefully how it comes off with one thick washer (blue plastic, one thin washer with lip made of black plastic). Put the new one on and hey presto all done!
cheers Scott |
*Smart *** comment here*
out of interest how much is the switch, mine died a few weeks ago, it's jerry rigged at th moment cause i have had timme to actually get or install a new one, 7 day weeks are a ИИИИИ... anyways, rough price on one?
1997 4.0L EL Falcon GLi Sedan Auto ---------------------- 2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe Lowered all round on King Spring Super Lows Tinted Windows, Pioneer MP3 Player and Audio System K&N High Flow Air Filter Mounted in Original Air Box Trip Computer NGK Sports Performance Leads NGK Sports Plugs Autotecnica Oil Catch Can
I payed $40 for one about 12 months ago
[EBGLT]
I think my mums el brake switch went about 10 times!!!!!!!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
As I said definately go to repco. $9.60 is an excellent price. And they look identical. Spend the 30-40 bucks your saving on something else.
cheers Scott |
turbo kid
thanks guys, ive basicaly found the problem. mate had a look at it and he just refitted it and it was most probably a faulty connection or whatever. sall good, works now. went for a spin and came back with a FAT smile on my face.
guess ill be sticking with this one for a longer time. |
#12 | ||
[EBGLT]
You got lucky mate!! Didnt have to spend anything!!
#13 | |||
#14 | |||
#15 | ||
Bugger I got ripped off! I'm going back to demand my 42c refund! lol
cheers Scott |
#16 | |||
