Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
19-07-2011, 11:31 PM | #1 | ||
Hi Matt,
Hoping for a bit of advise for my AU XR8. I've previously upgraded the front brakes to 330 mm RDA069s and HPX pads using brackets and longer hoses which has made the car stop a lot better, although it was fairly dear at $750 and 2 days of messing around. Looks good in the front wheels too :-) The opportunity has now presented to upgrade the rears to BF1 XR8 with RDA discs and HPX pads for about $350 and a day of stuffing around. I have the calipers already and so would need to buy discs and pads. I can do all the work myself. What I'm wondering is, given that the majority of braking is supposed to be done at the front wheels, would I actually notice any difference with the bigger rear brakes? Thanks if you can advise. Matt |
20-07-2011, 11:26 AM | #2 | |||
Race Brakes Sydney
Rear dba slotted are $200 a pair - the hats are also painted on these Rear rda slotted are $134 a pair HPX rear brake pads are $80 a set.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
20-07-2011, 02:55 PM | #3 | ||
Hi again Matt
Thanks for getting back to me. I think I didn't explain it properly. What I meant to say is that the calipers I have are for the 328 by 26 mm vented rear disc, so in principle it should give at least 10 % more leverage, and also be harder to cook. But the question remains as to whether upgrading rear brakes makes a lot of difference to the drive? Regards, Matt |
20-07-2011, 04:50 PM | #4 | ||
Hi again Matt,
When I say is it worth it, I could for example use this money instead to put DBA 4000s and A1RM or similar pads in the front, which would at least make it a lot harder to cook the fronts. So I suppose if one was trying to race this car on private roads, would one be better off with: - RDA 069 front discs and 328 mm rear discs with HPX pads all round, or - DBA4069 front discs with A1RMs and standard AU rears with HPXs. Thanks and regards, Matt |
20-07-2011, 05:01 PM | #5 | |||
Race Brakes Sydney
MATTHEW PEARCE
20-07-2011, 05:08 PM | #6 | |||
Race Brakes Sydney
i don't think iam with it today. I think the better option would be the 4069SL/SR 4000 series and A1RM up front with the BA set up on the rear just to give you a slight increase plus it bolts up fine.The BA rear set up would be much cheaper to buy as well. I have 4069sl/sr rotors in stock if that helps
MATTHEW PEARCE
28-08-2013, 02:13 AM | #7 | ||
Hi, I was just surfin through braking posts and found this one as it seems to point out that BA rear brakes can be placed onto AU rears with irs. I am wanting to know is this the case, all you need is just the calipers and rotors and they will bolt straight onto the rear of my AU series 1 IRS fairmont?
I really want something to fill the 19's in a bit better and perform better too. I have also been told about territory rear brakes, which awesomely are ventilated. Any help would be sweet, cheers. |
28-08-2013, 09:54 AM | #8 | |||
Race Brakes Sydney
MATTHEW PEARCE
