OK guys .... the Sprint is no longer a virgin ... a Dyno Virgin that is ;)
Before I announce the details I would love a bit of info on Dynos & the techniques used to do these ......... I have seen a couple done before but that was a few years ago in Victoria ....... Am actually wondering if the Mexicans do it different orrrrrr did the guy I use have NFI !!!!!!!!!!!!!! Questions I have are: At what speed does a Dyno operator pull out so to speak ????? What gear (Auto) is a dyno done in ????? Is it usual for a car to be tied down ????? How many cords/ leads go under the bonnet ????? |
#2 | ||||||
You have; - knock sensor which has head phones attached. So the dyno op can hear everything. - Tacho sensor attached to no 1 lead - Air temp sensor - Vac line Most dyno ops will have a timing light also attached at varying stages.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
#3 | |||
Hello
Firstly, dont worry too much about what a dyno says. Each dyno is different, and the atmospheric conditions are usually quite influential on the final figures, particularly air temp and humidity. This can also be influenced by the size of the fan in the dyno, if any. Cool and dry temps are best. Means denser air. If you get a lower figure, it doesnt mean much as many cars with lower dyno figures are actually faster than ones with higher rwkw - mine is a classic example of one with a reasonable dyno result but relatively poor track times compared to other cars with lower dyno figures. So that means that you car MAY pull a lower power figure on the dyno but flog a lot of more powerful cars anyway. Being auto can give a lower dyno reading too. Question 1: Dyno operators usually stop when peak power has been reached and the graph begins to decline again (from what I have seen) - there is no point in continuing to a certain speed if the peak power has been reached and the graph is heading back down. However, I THINK most DDD have a speed limit of 200kmh, apparently for safety reasons etc. Question 2: Dynos are usually done in higher gears to give a more accurate reading at the wheels. In manuals, 4th is ideal as it is 1:1 but often the speed limit is reached before maximum power, so often its done in 3rd. Sometimes they are done in 2nd but that usually gives a higher and less accurate power figure. Im sure someone else on here will be able to give you a much more accurate and technical explanation - perhaps see the sponsor sections say, Autotech, G&D, Bluepower etc - those guys do this stuff all the time. Question 3: Cars are not often tied down, but very powerful ones are, from what I have seen, to ensure cars do not fly off the rollers. Im not sure if it is an advantage or not with a reasonably powered car. Question 4: No clue, sorry. I have mainly just seen leads which run to laptops and devices in the exhaust, I guess to measure air and fuel. A low dyno figure may just indicate that your car is in need of a good custom tune. Did the graph give you air/fuel ratios? If you have a low air/fuel ratio, it is an indicator it is running too rich and needs a tune - which means there is more potential in it - which is good! Hope this helps a bit. Jac ![]()
2008 FPV TERRITORY F6-X Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes. ![]() ![]() |
Turbo Falcon Fiend
C'mon Lisa...... I logged on just to see what you got..... dont keep me waiting.
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
![]() Join Date: Dec 2004
ok Lisa, here it is in simple terms.
1. Dyno should be run to redline unless the engine is still making power.. in which case they will take it as far as is safe 2. All BTR auto's (like yours) SHOULD be run in 3rd gear. As yours is a Sprint there is no reason to run it in any other gear as the 200kph issue wont apply and neither will the speed limiter. 3. If the car isnt tied down the reading is high.. period. If the car is tied to ONLY the the front roller the reading is still hight.. period. In general, the car must be tied down (hard) or it will crawl up the front roller, lose resistance and make a false reading. 4. This is open to debate however at least one should go into the intake to measure temps (and not into or on the radiator as this will "trick" the dyno to think ambient temps are high and to over compensate power loss based on temps... and give a false reading)
OK ....... I needed to know the first one mainly ..........
There is NO way in hell she was red lining ...... she was in 3rd and sounded sweet as ..... wanting more ........ I know that sounds silly but I do know what my car sounds like when shes working & she wasnt ...... Even my wonderful OH thought it was a bit off that she wasnt taken 'all the way' & that was before we saw the reading ...... She wasnt tied down at all ......... He took her to 160 & stopped ...... kept on saying for these things that was a normal reading ....... then we started talking & Im sure he was thinking a normal XR8 ....... He looked funny as we spoke of what she was & what she had as opposed to the standard ....... Must need a few more things done to her as she only pulled a 150hp ........ |
#7 | |||
Take dyno reading Throw in bin Ignore. Take it somewhere else, that reading is totally and utterly pointless. May as well be another cars reading.
#8 | |||
#9 | |||
#10 | |||
Hello
I take it that is 150 RW hp? Converted to rwkw, that is about 112rwkw? That seems quite low - would have thought 140rwkw ish? Perhaps it is in need of a good tune! Perhaps the dyno could be done elsewhere to see if its consistent... Did you get an air fuel ratio reading or a tractive effort reading? Can you post the graph?
Will be doing that for sure Capser.....
Knew it wasnt right ..... just needed to know that this thing wasnt done as I thought it should be ...... I didnt want anyone to think I was just whinging cause I didnt get what I expected. |
#12 | ||
There was no air/fuel done ... hence the question on how many leads are normally used ..... there was one in the air intake & that was it ......
I havent got a scanner here but can post tomorrow at work ..... not that theres much to see on this one ........ it is a very bare reading to say the least. |
#13 | |||
Hello
#14 | ||
Turbo Falcon Fiend
Lisa, I wouldnt worry about what the Dyno has said - it seems there are lots of reasons the Dyno could be off.
As long as you are happy with the performance of the car (and we all know it looks great) I would ignore the Dyno figure and try something else (another Dyno, a G-Tech etc.... ) The actual horsepower figure is probably not as important as the torque and the power delivey.
#15 | |||
#16 | |||
Hello
Is there any kind of scale on either of the axes, with the graph? Roughly, what does the curve look like? Does it reach a peak and come back down towards the end or does it keep climbing as it ends? Is there data at the bottom about air temp, humidity etc?
#17 | |||
Hello
#18 | ||
Proberly easier if I post the piccy tomorrow ....... theres no other info on it apart from the HP reading ..... have a KW one too ...... that looks worse figure wise :P
Is a decent incline upto 135k's then flattens out as did the guys foot ....... Im really not whinging ...... just need to know if I have a dud engine .... which after driving her home I doubt .... she copped a bit .... just to make sure it was there :P |
#19 | |||
Hello
Do you mean it flattens out at about 135kmh or 135rwkw or 135rwhp? The graph flattening out is about the power output at that time, which would not related to when the bloke took his foot off. If the curve declines before it ends, then it means that he didnt take his foot off too early as the peak poiwer had been reached and was declining, even though speed was increasing. Once you reach peak power and then it declines, there isnt a lot of sense in keeping the foot to the floor and damaging the engine, just to get to the fuel cutout point. It sounds like in that respect the bloke was ok. It is just a matter of determining what the peak power was and where it was at, in relation to revs or kmh (which is why I asked about the axes). It is a shame there was no air/fuel ratio given as that may give an indication of why power may have been lacking. Im also wondering about the tying down issue. I cant say that I have ever noticed cars being tied down, but then, I never really look at the front of the car on the dyno so I dont think I would know. I have assumed my car has never been tied down because I never saw it, but Eamon assures me that it was tied down at all the dyno days we have been to. I was thinking of the big straps used for the 300+rwkw XR6T that we saw but it appears I was thinking of something different. I would be checking with the bloke to see what he actually DID. I also think that if the numbers are unexplainably dodgy, then defintely get it done somewhere else and get more info on the prinout - Im sure the people doing it would be able to offer an opinion as to why a car would be so underpowered, even if it was a defensive answer... LOL. If it was not a Dyno Dynamics Dyno, I wouldnt have gone near it, personally, but you should be able to tell that by the graph you have. It sounds suspiciously like its not. Having said that, just bear in mind mate, that dyno figures dont mean much. Its the driveability of the car, the power you can feel in your bum when you floor it and the ETs/mph that give you a better picture of what you car is capable of - as you said, you know how it feels! You know your car and you are probably correct. At the end of the day I guess a car the same as yours should be getting closer to 130-140rwkw (in my opinion) conservatively so a figure of 112 rwkw is low for some reason. Anyways, look forward to seeing the graph and also to hearing some more technical opinions on the subject from people who know a ****load more than I do!!! Jac ![]() PS I think everyone will agree with me when I say it is unlikely you have a dud engine. It seems that a dud dyno is a possibility and at worst, the engine is good, but just in need of a good tune! And the real purpose of a dyno is to do just that - its a tuning tool!
#20 | |||
You have to let the car ride up the front roller otherwise you wont get a reading from the back one! A mate has a sprint,auto, i remember it had about 190-200 rwhp. The air/fuel lead is the one that goes in the tail pipe. |
#21 | ||
OK heres the piccy of the dyno ......
Am going to try get her booked into the only other place that does it up here ...... that or wait till I get to sydney next & get one of the site sponsers to do it for me with a complete explanation ![]() |
#22 | ||
Two > One
Definatly not done correctly Lisa. Wasnt performed in SHOOT_8 and definatly looks as if someone backed off the rollers. DDD's have no issue going over 200kmh, well aparently they don't. My run went to 204kmh iirc.
I wouldn't worry too much about a sheet of paper lisa. As long as you are happy ;)
#23 | ||
I am rapt with the car ..... Its just a bit annoying to realise that you have paid for something and not got what you paid for ........
I was hoping for real detail so I can make plans for what we want to do with her in the near future ;) |
#24 | ||
NOTTY
Every dyno you go to you will get a different reading
#25 | ||
I'm assuming the diff in the Sprint is a 3.45...
135kph in 3rd (auto) would mean only around 3800rpm? |
#26 | |||
This dyno operator sounds a little lazy as was just after a quick buck.
#27 | ||
Hello
Not good Lisa. There seems to be a lot of data missing as well, like all the atmospheric stuff at the bottom of the sheet such as air temp, humidity, etc, etc.... sort of indicates, yes, lazy bloke as it probably wasnt measured.
I see what you mean about that curve, and yeah it does look like he backed off, doesnt it? I would have been questioning that a bit, can you contact him again??? Thats pretty bad service. As Dan said, dont worry about it too much and if you want to know more, get it taken somewhere reputable, as you have said. Good luck mate! Jac
