16-07-2006, 09:35 PM | #1 | |||
Everyone probally has seen fuel savers on ebay make all sorts of amazeing claims, but has anyone fitted them to a big 6cyl or V8 (& are willing to admit it) & can speak from experience.
The one I was reading about was "Fuel saver Plus" I know Repco have a product called Vapourite & I have not heard people with it saying its been a great investment. What is Fuel Saver Plus: Fuel Saver Plus is the most powerful fuel saver every made. It is Powered by Neodymium rare earth magnet with a force of 25,000 Gauss. It is the strongest and most powerful fuel saver you can ever find. Recommended for all engines. How does it work : Placing the Fuel Saver Plus , on the Supply fuel line, causes the hydrocarbon molecular clusters to seperate and expand. More Oxygen will now combine, with more of these hydrocarbon molecules, which are no longer in clusters, for better, more efficient combustion in the firing chamber. Since Fuel is now burning more Efficiently, the result is reduced emissions, less fuel needed to reach and maintain speed levels. Carbon and Varnish build-up is lowered, thus reducing maintenance and extending engine life. A "cleaner and hotter" fuel burn also increases Horsepower and overall engine Performance. The Fuel Saver Plus accelerates combustion and burns more of the fuel that is normally exhausted as un-burned pollution. FEATURES : Increase mileage (Fuel saving of up to 27 %) Works on petrol or diesel engines Extends engine life by cleaning existing Carbon/Varnish Deposits Boosts Performance / Horsepower Reduces harmful Exhaust Emissions Use for engines up to 16 cylinders. Fuel line Smoother running engine by promoting a more complete combustion Install in less than 5 minutes with no Tools needed !!! Maintenance Free and One time purchase Can easily be transferred to another vehicle. Benefits : Pays for itself within a couple of months from your fuel's bill Improves mileage up to 27 % Enhances energy performances! Reduces carbon monoxide emission Smoother and quieter enqine! Cleans engine, carburetor and spark plugs! Environmental friendly! Maintenance free! Easy to install! Does not effect vehicle warranty! Engine sound will be changed from Sino cycle waves to square waves. Engine temperature will be decreased. At Gas burner , it will change the flame from orange colour to blue colour. At waterline, it will change hard partices of water to soft particles.
FGX XR6 Lightning Strike Sedan BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw. Quote:
16-07-2006, 09:56 PM | #2 | ||
If it really did affect economy, wouldn't the manufacturers put them on as standard?
My first E-series: (*gone* :() 1994 EF Futura Current Ride: 1993 Ford Telstar GLX, maroon manual sedan, Alpine CD player |
16-07-2006, 09:59 PM | #3 | ||
Unless people start raving about it, not the manufacturer or distributor, i wouldnt waste my time on these things.
16-07-2006, 10:11 PM | #4 | ||||
17-07-2006, 04:02 PM | #6 | |||
Cuban... nothing like it
05-09-2007, 12:01 AM | #7 | ||
theres a new one on the net called powermag or something like that... for around $50 you they reken a savings of 30%... I could do alot with $50 with premium unleaded in the tank.
If there only just magnets why not get some and DIY fuel saver... Magnets are magnets there all the same. Cheers, Will
dynamic white ED falcon - was stock as a rock. |
05-09-2007, 12:36 AM | #8 | ||
He has, the Knack..
How exactly does a magnetic field interact with a non-metallic liquid and cause "clusters" to separate and expand? Separte, I *may* believe as hydrogen can be affected by magnetic fields but im 99.99% sure it wont affect a hydrocarbon. But it won't cause a molecule to expand More Oxygen will now combine, with more of these hydrocarbon molecules, which are no longer in clusters, for better, more efficient combustion in the firing chamber. If you believe the first paragraph I could see why you would believe this one, causing you to validate the first paragraph in your own mind. But the combustion of the fuel depends upon the surface area of the droplets, not the area in between "clusters". Just thinking about it, assuming you have the same size fuel droplets (as your injectors are the same) and *if* it causes the "clusters" to "separate and expand" then you will have less fuel molecules per droplet, so less fuel per cycle, so less combustion so less power! Since Fuel is now burning more Efficiently, the result is reduced emissions, less fuel needed to reach and maintain speed levels. This would be true if the stuff actually worked Carbon and Varnish build-up is lowered, thus reducing maintenance and extending engine life. How? You arent adding anything extra to act as a cleaning agent, just "re-arranging the clusters" A "cleaner and hotter" fuel burn also increases Horsepower and overall engine Performance. Ok but it still hasnt done anything to get to this point FEATURES : Increase mileage (Fuel saving of up to 27 %) Massive saving! Id love my BA to get 7.8L/100km! Works on petrol or diesel engines - Yep, doesnt do anything for either Extends engine life by cleaning existing Carbon/Varnish Deposits - Reducing the build-up, or cleaning it? Make up your mind! Boosts Performance / Horsepower Pull the other one Reduces harmful Exhaust Emissions See above Use for engines up to 16 cylinders. Fuel line Smoother running engine by promoting a more complete combustion See above Install in less than 5 minutes with no Tools needed !!! Morons buy them, so they need to make it simple enough for them to install! Maintenance Free and One time purchase Cause it doesnt do anything! Can easily be transferred to another vehicle. See above Benefits : Engine sound will be changed from Sino cycle waves to square waves. WTF? Has anyone heard a square wave? They are awful Engine temperature will be decreased. By promoting a hotter burn? At Gas burner , it will change the flame from orange colour to blue colour. So you are increasing the temperature of the flame but claiming a cooler engine? At waterline, it will change hard partices of water to soft particles. LOL hard water is water with a lot of calcium, etc in it. Its hard to make soap lather in it. Besides id be concerned if there was enough water for there to be a water level inside the combustion chamber! So yeah, they are a load of garbage
2010 BF MKIII Falcon wagon "EGO" Workhorse, stock as a rock 2004 BA MKI Futura - Now the wife's For Show: 18" Kaotic Shadow Chrome, King SL all round, Cadence Amp, Kenwood 12" Sub, JL Audio 5x7's, Scuff Plates, MP3 Connector For Go: SVI LPG, K&N Filter, F6 CAI, XR6T snorkle, XR8 catback, Magnaflow metal cat, Pacemaker headers, Underdrive, Thermostat, Custom tune, DBA4000 Now with baby seat and toys 175.6 rwkw www.bseries.com.au/King_Nothing |
05-09-2007, 01:26 AM | #9 | |||
Force Fed Fords
King Nothing is right. Additionally, where does the oxygen they claim that attaches to the hydrocarbon come from? If it came from the induction wouldn't the MAF sensor pick it up and negate it for running too lean?
Inside a fuel line there is no oxygen so I assume it comes out of the manufacturers rear end. Secondly, vexatious calims like this can have disastrous results. Some idiot stuck a fuel saver in his Jeep which resulted in the engine catching fire. This made Today tonight and they made the rather spurious claim that it was the fault of chrysler. What they failed to disclose has them in the supreme court for failing to mention the modification that indeed caused the fire, as well as defamation of the chrysler brand. Finally, before committing to modifications like these you can assure yourself that they are BS by the fact that car makers spend billions globally on a competitive edge on fuel consumption. If a $50 magnet shaved 30% off you can bet that the manufacturer would have installed it.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
05-09-2007, 08:25 AM | #10 | ||
I think that most people dont know what their fuel consumption actually is and then believe that these save fuel after they purchase and then take some note of the fuel running with no real comparison beforehand.
05-09-2007, 09:00 AM | #11 | ||
Back where I belong
Send me 200 bucks and I will lower your fuel bill by about 80%, I will just come around and stick a brick UNDER the accelerator and you wont be able ot accelerate more than 20 % thus saving you 80%.
Regards Craig |
05-09-2007, 09:27 AM | #12 | |||
Can you post to newcastle? |
05-09-2007, 09:38 AM | #13 | ||
I see you....
A fool and their money are easily parted......for exmaple see above !
05-09-2007, 09:54 AM | #14 | |||
flickr |
05-09-2007, 10:43 AM | #15 | ||
Wonder if mythbusters have a show on this one before??
Get them on the case, they will do somthing, they will try and bust it haha! On a serious note, in my old job (sales rep for aftermaket accessories for motro cars) I rember on 2 different occasion's blokes coming in to try and make me sell a fuel save additive. His claims was similar to the above but was added to each tank and after approx 5,000ks you would see the differrence. increase of approx 20% in economy. 1 bloke seemed a dogy dude, but the 2nd was a reputable company that make alot accessories. Never tried the product wasnt game enough. |
05-09-2007, 11:00 AM | #16 | |||
Haltech 302w XW
1969 XW Fairmont-1999 explorer 5.0- comp cam XE270HR, 9.8:1comp, Ported Gt40p, Ford Racing oil Cooler, EL V8 radiator & thermo's, Fuel/intake -XR6T injectors, 255 LPH intank pump, 4" intake, HaltechE11v2 Exhaust-custom Tri-Y headers, Twin 2.5" HiFlo Cats, duel 2.5" exh Driveline-close ratio 4spd, 9" LSD, 300mm AU XR8 fr, XC rear, ZH Fairlane Mas/Cyl & Booster Project car: http://www.fordforums.com.au/showthread.php?t=21641 |
05-09-2007, 11:19 AM | #17 | ||
lpg = big boom!
i have dried the "dynotab" fuel additive.
its an octane booster and a cleaning solution. it works quite well, only a few % of difference, but the power pickup is much better.. but thats most likely due to the injectors being clean... mahaha
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM |
05-09-2007, 01:12 PM | #18 | |||
05-09-2007, 02:06 PM | #19 | ||
i dont believe in any of those fuel saver things!!!
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
05-09-2007, 02:18 PM | #20 | ||
I might make a fuel saver and sell it on the net, maybe a chunk of wood that you stick under the gas pedal to prevent you from reving the car past 2500rpm. If people by hyclones surely they'll buy this
05-09-2007, 04:49 PM | #21 | ||
Where to next??
There was an article on the news about this sotta stuff, and it got me thinking.
Just say you add every available fuel saver on the market, I fugured this would result in a saving of over 100% combined?? So.... your car will be making petrol, not using it lol. |
05-09-2007, 04:50 PM | #22 | ||
Cracked Pot
Install 4 of them and you'll be draining the fuel from the tank.
Ford Faithful
05-09-2007, 08:06 PM | #23 | ||||
BA Falcon XT
yes mythbusters did something on this and they were all a load of crap. i think it was on last seasons which every one that was the other one that didnt try was that australian one that repco seel hiclone or whatever, still not sure on this one for $400 a mate had it on his ED didnt give him a fuel saving at all but he said he got a bit more power from it, but for the price i would rather spend it on something else
Click here to check out my signature http://i238.photobucket.com/albums/f...ignature-1.jpg Quote:
05-09-2007, 08:15 PM | #24 | ||
If its too good to be true, it probably is.
A philosopher is a person who finds a problem for every solution . :Reverend: 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
05-09-2007, 10:03 PM | #25 | ||
LPS
There's a lab I know of that has had many of these come through for evaluations and certifications. Guess how many have actually worked - not one.
06-09-2007, 12:27 AM | #26 | ||
I though about it ligit, but then i thought about how i could improove the fuel consupsion by
-new fuel filter -regulator - clean injectors -correct tyre pressures - bearings/brakes to see if anything was rubbing or unneeded friction that would cause the car to consume more fuel. I agree with some of the posts that have said how dodgy these are! I like the bloke of wood idea. But i guess it comes down to a feather foot instead of a lead foot i guess. Cheers, Will
10-09-2007, 04:46 PM | #27 | ||
I have a friend who invented www.ifuel.com.au and it does work.
It has been proven by Bosch and is going to be available in many workshops. It cleans the motor of the carbon deposits and this makes a significant difference to many aspects of the car.
Fordless..... |
13-09-2007, 01:59 PM | #28 | |||
I see you....
No offense intended. |
13-09-2007, 02:27 PM | #29 | ||||||
Secret Sleuth
BF Mk2.5 XR6 Turbo |
13-09-2007, 02:57 PM | #30 | |||
