Old 05-08-2019, 09:54 AM   #1
GT0336
GT Pilot
GT0336's Avatar
Default MC Mondeo forward alert malfunction & ABS Light
My wife's 2012 Mondeo Titanium Ecoboost, has a problem that I am trying to troubleshoot. The ABS and stability lights are on, as well as a forward alert malfunction.
I've scanned with an OBD tool but the car is showing no fault codes. I've tried disconnecting the battery, cleaning the front radar and connector with contact cleaner.
Has anyone else had this issue? I've also noticed the powershift Auto seems to roll back when in gear, but does shift gears fine and the hill launch feature is unavailable. Thanks in advance for any help.
2005 BA MK2 FPV GT 6 SPEED MANUAL.
LOWERED WITH BILSTEIN AND LOVELLS SPRINGS, CUSTOM QUAD EXHAUST, PACEMAKER HEADERS, 200 CPSI CATS, CAI, 80MM THROTTLE BODY, SHAKER, FACTORY SAT NAV, REVERSE CAMERA, CUSTOM ALPINE/DLS SOUND SYSTEM. CUSTOM GT-P LEATHER SEATS BY LEATHER-FX.
TUNED BY SPIRO AT AUTOTECH - 287.9 RWKW
Build Thread
2009 SY FPV F6X
2017 Mustang GT
GT0336 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2019, 11:23 AM   #2
steerage250
Default Re: MC Mondeo forward alert malfunction & ABS Light
I have a similar issue with our MC 2012 titanium Ecoboost, but just limited to the forward collision alert. The warning lamp for the forward collision alert is on, and yet the adaptive cruise control works just fine - and they use the same sensor (I'm assuming - I can only see one likely candidate in the schematics called the Proximity Warning Radar Unit).
Like you, I have checked for diagnostic codes with an OBD tool.
I found this description in a manual for a 2014 Mondeo, and perhaps the same applies to our year:
"The CCM (Cruise Control Module) monitors the yaw rate signal from the ABS module and compares it to the wheel speed and steering wheel angle signals. If the ABS module determines the yaw rate is invalid, the CCM disables the adaptive cruise control. The message center displays the message COLLISION WARNING MALFUNCTION and/or ADAPTIVE CRUISE MALFUNCTION."
- so maybe it's something to do with the yaw rate ?
steerage250 is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2019, 07:11 AM   #3
bundybear75
bundybear75's Avatar
With regard to the roll back in drive with the powershift, it would be no different to a manual gearbox with your foot on the clutch. There is no "drive" forward like a traditional auto when stationary.
The hillstart assist feature will help with this, and can be turned on using the steering wheel controls/
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2019, 09:56 AM   #4
Mondaveo
Mondaveo's Avatar
What kind of OBD tool did you use to look for fault codes? Mondeo has two controller networks, HS-CAN and MS-CAN. Most garden-variety OBDII readers can only read from the HS-CAN. If this is yours you may find you can expose more information getting one to read MS-CAN.
There is a thread on the topic here: https://fordforums.com.au/showthread.php?t=11449047
From the issues you're describing I don't think there's a problem with your radar sensor, it seems more likely the issue lies somewhere in the braking system, maybe the ABS or the yaw sensor as steerage has suggested. Think about it: collision alert, traction control and hill launch all require the computer to control the brakes, and if something is wrong with that system it will impact all those other automated functions.
Hope that helps and you get it sorted
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is online now   Reply With Quote Multi-Quote with this Post
Old 14-08-2019, 11:24 AM   #5
GT0336
GT Pilot
GT0336's Avatar
Thanks for all the replies. I've now scanned the car with FORScan and have a fault in the rear right ABS sensor. I'll order a new sensor and hopefully this solves the problem.
Build Thread
2009 SY FPV F6X
2017 Mustang GT
Old 24-08-2019, 08:53 AM   #6
GT0336
GT Pilot
GT0336's Avatar
Fitted the new ABS sensor and still no luck. Still getting the fault and ABS light after clearing codes.
Build Thread
2009 SY FPV F6X
2017 Mustang GT
Old 24-08-2019, 09:01 AM   #7
Peter B - CV8
Check any wiring harness in that area for continuity. Early VE Commodores used to report a similar problem. The fix was a new harness..
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2019, 11:43 AM   #8
GT0336
GT Pilot
GT0336's Avatar
Just an update for anyone else that has this issue. The problem was in the ABS sensor harness. Made up a new harness and all fixed.
Build Thread
2009 SY FPV F6X
2017 Mustang GT
