Old 13-04-2024, 09:50 PM   #1
mad2
Regular...with metamusal
Default Hill Descent Re Territory's
Evening All.
question today is - when was the Hill Descent control button fitted to the Territory & what model plus what did the "Hill Descent" button control?. have found a Terri with that particular button and it made me wonder about it.
Thanks
Old 14-04-2024, 09:23 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Hill Descent Re Territory's
I believe it became optional on the AWD models from 2007 onwards.
Observatio Facta Rotae
Old 14-04-2024, 06:37 PM   #3
mad2
Thanks Big Boss .... yeah i saw the switch in '04 SX [on the left], which i thought was odd.
Old 14-04-2024, 09:12 PM   #4
XR Martin
XR Martin's Avatar
ABS system is completely unique I believe.
2004 BA wagon RTV project.
Old 14-04-2024, 09:40 PM   #5
mad2
would have to look at the wiring etc .. but your probably correct
i would know who to call ......... coz they knew their shiite..
but i don't have their new number
[miss im much]
Old 14-04-2024, 10:09 PM   #6
Hill Descent supplies an earth to Pin 36 of the ABS/ESP module. It applies to modules with steering and yaw sensors, so I suppose ESP only…
Old 14-04-2024, 10:42 PM   #7
PG2
#neuteredlyfe
PG2's Avatar
Hill descent control was optional on all AWD models from release.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 08:32 AM   #8
mad2
another job to add to me list
thanks peoples
Old 15-04-2024, 11:15 AM   #9
Dr Smith
Thanks..was going to ask my wife tonight what she did to the switch that's missing...
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2024, 05:36 PM   #10
mad2
well ...... i've just checked out the steering column .. it has the sensor on ze column!
not sure if/how i can check for the yaw.
Many Thanks for that info ..... i also checked out the blanked switches spot .... has one plug there so i will look closely at the relevant wiring diagrams.
Ps.
have checked out the wiring loom/Commodorenutt's manuals ...... it 'appears' i have the loom for the hill descent ..
i presume i will have to pull apart the ABS wiring plug to check for this earth/pin 36 to verify the above then yes?.
Old 15-04-2024, 06:12 PM   #11
mad2
and also .....
while we're at it - how do i test the "hill Descent" button feature out?. do i need to enable anything?.
Old 15-04-2024, 06:50 PM   #12
The brake module plug has tiny numbers on the end pins of each row. See if 36 is populated on the harness side and on the actual module.
If so, try buzzing it out from the blanked off switch connector.
Originally Posted by mad2 View Post
and also .....
Good point, your area isn’t exactly mountainous.
Old 15-04-2024, 08:43 PM   #13
mad2
great! .. tiny writing.....
that i can do ........ yeah .. lot's of hills here
Ps. i'll have to put the original cluster back in to check as it currently has the cluster from BAFLR6 fitted......
Old 16-04-2024, 06:09 PM   #14
mad2
tried out the switch .......... without a 'hill' i didn't notice any thing .. no lights etc etc. the original cluster was also refitted with both showing nada.
Old 17-04-2024, 09:30 PM   #15
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Correct. I had it in my 2004 SX.
Correct. ABS module stamped HD.
Dhru (RIP) considered fitting it to the FAWD. We exchanged a few posts on the topic in his mega thread, I don’t think he ever sourced the unicorn ABS module, it was a very expensive (niche) option.
Further reading > Enabling Hill Descent Control
Cheers, Raptor
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2024, 09:38 PM   #16
mad2
Cheers, Raptor
Thanks
Old 22-04-2024, 10:42 PM   #17
mad2
Cheers, Raptor
so i presume mine is not the one your refering to??
OK, on my HDC enabled '04 SX (with a torch in the dark) I get ;
  • part no. GR73-2C405-BA (but maybe it was 6R73...?)
  • big letters at the front, I have 2 of them => HD (Hill Descent?)
Maybe F equals Free wheeling and HD equals Hill Descent.
where as mine finishes in -AA and doesn't appear to have the HD ?.
