Old 15-01-2012, 07:31 PM   #1
cortEA
cortEA's Avatar
Default wont rev past 4200 rpm
Hi all, I have bit of an issue with my AU 6cy powered Cortina. As the title states it wont rev past 4200rpm. we have tried both with and without boost to no avail. wondering if anyone else has had a similar problem and what they did to fix it. the computer controlling it is a Haltech E6X. any help would be greatly appreciated
Cheers Corey
My car: '99 AU XR6 VCT, XR50 front bar 5 spd, pacemakers, 2.5" zorst and K and N panel filter. 1/4 15.02 at 94MPH, 162RWKW
Missus car: 04 Subaru Impreza RS with fully sic cannon
Drag car: '76 TD Cortina, 4.0 AU motor, 4 spd single rail, 4 puck solid centre brass button clutch, 17" chromies, 600*300*76 FMIC, Garrett TB 4133 Turbo, BA XR6T inj's, Malpassi, Walbro etc etc...
cortEA is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 07:43 PM   #2
dieseltrain79
Default Re: wont rev past 4200 rpm
Havent got a rev limiter at the moment ? Or Blocked Cat ?
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 07:52 PM   #3
cortEA
cortEA's Avatar
Nope no rev limiter and full straight through exhaust. only drag car dont need a cat...
Old 15-01-2012, 09:46 PM   #4
T3man
T3man's Avatar
what's the history - is this something that has just occurred and under what circumsatnces did the problem first appear? Have you hooked up your laptop to the Haltech to view the fuel/timing/boost etc to see if anything has gone awry?
Old 15-01-2012, 09:58 PM   #5
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Being its a haltech ECU, i would say the problem is probably something more to do with ignition module/dwell settings. Ask haltech for help on there website.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 10:10 PM   #6
SirHenry
Falcon Unbelievable!
Coilpack?
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 10:23 PM   #7
dieseltrain79
Running the Haltech Igniter ?
Have you checked fuel pressure ?
When you say wont rev past ot , does it missifre or just flatspot ?
Old 15-01-2012, 10:49 PM   #8
cortEA
cortEA's Avatar
seems to more just a dead stop no real misfire. It is a coilpack from series 1 AU. running a bosch triple channle ignitor. have had the laptop hooked up and checked the afr with a wideband etc. i'm guessing the problem has been there since we have had it running. it is booked in to be tuned this coming fri so will be interesting to see what they find. Thanks for your thoughts and ideas so far.
Cheers Corey
Old 18-01-2012, 11:57 AM   #9
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Good luck Corey. Hope that you get it sorted.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
