Old 20-02-2012, 10:30 PM   #1
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default AU weathersheilds.
Does anyone have any Genuine AU weathersheilds laying around that they don't want anymore ?.
Also how do they attach to the vehicle ?.
Old 20-02-2012, 10:33 PM   #2
Murph-51
Murph-51's Avatar
Default Re: AU weathersheilds.
yeah i know of a pair, but the car comes with it :(
I will try to suss out though and see how they attach though
Murph-51 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 10:38 PM   #3
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank's mate, I assume they attach by double sided tape but I want to know if they go under the rubber seal and the tape attaches there, or does it attach to the paintwork, the main purpose of knowing this is if I decide to remove them in the future will they leave damage if they have been attached to the paintwork ?.
Old 21-02-2012, 09:15 AM   #4
b2tf
not here much anymore
b2tf's Avatar
Check Bayford Parts on Ebay, they have a lot of genuine Ford stuff from the AU era listed at the moment.
As for the fitting, from memory the double sided tape attaches them to the rubber on the door around the window so if you take them off there would be a mark.
RAM 1500
Old 21-02-2012, 09:59 AM   #5
KITBAG
KITBAG's Avatar
They are attached by double side tape on paint work. (Red arrows and line).
There are three metal clips that sit on the black rubber on the window edge (Shown by Yellow arrows).
Hope that helps.
KITBAG is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2012, 11:21 AM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank's guy's the ones I am considering are the slimline weathersheild's, not the bigger ones.
Old 21-02-2012, 11:35 AM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
kitbag is right
also you can remove them no problems, it doesn't leave a mark. a bit of good car polish is all you need to remove any residual glue.
Old 21-02-2012, 11:37 AM   #8
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
I have the slimline ones. Attatches the same as shown above, but just with the doublesided tape. This pic is the closest I have to show
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2012, 12:37 PM   #9
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank's for that guy's, I guess once there on they will be staying on so it's not that big of a deal if they leave mark's.
Old 21-02-2012, 01:00 PM   #10
AU Mont
i had the full size weathershields on my last car, they were great
im still not sure of the purpose of the slimline ones though?
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2012, 02:43 PM   #11
Mr Hardware
I have slimline's on my corolla and they're not as good as fullsizers, but still about 3000 times better than not having any
Old 21-02-2012, 05:37 PM   #12
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
They do stop some wind, and certainly stop water dropping inside the car when stationary. When on the move, they also deflect water rolling off the windscreen - especially when using the windscreen washers.
Stu
2002 AU II LTD
Old 21-02-2012, 05:53 PM   #13
galaxy xr8
Giddy up.
galaxy xr8's Avatar
They would be handy to have when it's in summer and it's muggy ouside but slight drizzle, just enough to let some fresh air in and keep the rain out and stop the window's from foging up aswell.
Old 21-02-2012, 08:55 PM   #14
AlfaRomeoGTV6
T Series Club Member #041
AlfaRomeoGTV6's Avatar
Mate I have the slimline type fitted to my car and would not want to be without them.
T-SERIES Club of Australia
2002 T3 TE50 Build #099 Winter White/Blue & Black
AlfaRomeoGTV6 is offline   Reply With Quote Multi-Quote with this Post
