Old 16-07-2012, 05:38 PM   #1
EBW-302
EBW-302's Avatar
Default Egas 6cyl to V8 Conversion
Been toying with the idea of converting to V8 in my AU3 Egas.
Is there anything that is different to just converting a petrol AU to V8?
Will I need to upgrade to GRA throttle body and a different convertor or gas ECU?
Obviously the car would be running on straight gas which is often done, just havent seen an Egas converted.
2009 BF MK3 XT EGAS WAGON
PREVIOUS RIDES: 2002 AU3 FORTE EGAS WAGON - 1995 EF GLi WAGON - 1991 EB GL WAGON V8 - 1998 EL FAIRMONT TURBO
phat GUARD ROLLING | 0429 093 302 | facebook
"CHEAPEST GUARD ROLLING IN MELBOURNE"
EBW-302 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2012, 12:09 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Egas 6cyl to V8 Conversion
Lol, surprised no-one else has replied yet...
Use all the V8 stuff, but when it comes to fuel lines, just block them up and unplug the injectors...
You can use a GRA throttlebody and convertor, but you will have to move the convertor... Use the petrol pump +12v with a fuse for the LPG lock offs (its how I've seen other straight gas cars converted like the AU 'Lane)
btw, if you wanna convert to climate control, good idea to do it with the conversion.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2012, 09:46 PM   #3
XRGhia
meh.
XRGhia's Avatar
Oh, and Pete, don't forget the blower :P
Old 18-07-2012, 06:28 PM   #4
EBW-302
EBW-302's Avatar
Is it a dash/wiring swap in AU's? Kframe is the same aswell?
Old 18-07-2012, 06:39 PM   #5
madwag
madwag's Avatar
Im fairly sure the K Frame is the same as a 6
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build.
http://www.fordforums.com.au/showthread.php?t=11349360
Weekender: '69 VW Notchback
http://www.fordforums.com.au/showthr...24#post4531824
madwag is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2012, 07:24 PM   #6
XRGhia
meh.
XRGhia's Avatar
Nup, dash loom and stuff are the same I6 to V8... Same with K-Frame (same since EF :P)
Old 18-07-2012, 08:32 PM   #7
KR1STO
Just another mock-up..
KR1STO's Avatar
Petey..!
It's a great idea to do the swap, I'm glad I did mine..
Now a small list of things to do,
If the ECU, BEM & Key have to all communicate, you'll need to get it re-programmed when you fit a S3 V8 ECU.
You'll need the loom from ECU to engine, but all the dash loom and wiring will stay the same.
K-frame is the same, so you'll just need V8 mounts.
Intermediate shaft from steering column to rack.
Power steering lines are different
You'll need new fuel lines and will have to change the gas setup.
A/C lines
Exhaust
Umm, let me go back to my notes I made when doing mine and I'll get back to you on the rest.
It's not a hard conversion to do, I'd say do it.
The only issue will be the added expense of changing the gas setup and whether it fits into your budget..
What is the budget mate? I may be able to help you out with a conversion..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2012, 08:34 PM   #8
bartsau
bartsau's Avatar
K frame is 100% the same.
Wiring.
The way the battery is earthed is slightly different 6 vs 8. But easily fixed.
The positive from the battery to the starter motor is longer on the 6 as the starter motor sits higher than the 8. Again though easy fix.
The only other wiring so far that I have found different is the passenger side of the engine bay. 6 cly doesn't have provision for the passenger side oxy sensor the the v8 loom does.
Also, depending on the model the alternator plug may be a 2 pin or 3 pin. However, again an easy fix as there are only 2 wires regardless if it is a 2 pin or 3 pin plug!
Hope this helps. As I am doing the v8 conversion now this is all I have come across. However, I don't have it back together 100% and running yet so don't quote me.
Cheers,
Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2012, 03:40 PM   #9
tim_pato
tim_pato's Avatar
Soooo the same could be said for the vct? Dont spose a s1 vct ecu will work with the s2 bem?
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2012, 04:10 PM   #10
tim_pato
tim_pato's Avatar
to be more clear i have a s1 vct motor and loom/ecu and was uming bout putten it in my s2 egas ute
Old 22-07-2012, 04:43 PM   #11
bartsau
bartsau's Avatar
Nope a series 1 ecu is not going to work in a series 2 and a series 2 will not work in a series 3. And more so mixing anything series 1 with something later gets difficult as things changed from marlock to smartsheild.
Wagon Build
Toy Car Build
Old 22-07-2012, 07:25 PM   #12
tim_pato
tim_pato's Avatar
Hmf oh well was considering an aftermarket dual fuel ecu any way.
Old 22-07-2012, 07:26 PM   #13
tim_pato
tim_pato's Avatar
S1 loom S2 ecu?
Old 24-07-2012, 07:21 PM   #14
EBW-302
EBW-302's Avatar
So really I need a series 3 V8 ECU/cluster/engine bay loom to go with the engine/auto?
Then off to the LPG place to have the right stuff fitted to run on LPG
Old 26-07-2012, 11:48 AM   #15
XRGhia
meh.
XRGhia's Avatar
You don't need the dash loom, unless you want to do a Fairmont dash conversion Pete...
Yes to everything else.
Old 15-08-2012, 08:00 AM   #16
tim_pato
tim_pato's Avatar
what about the stepper motor? What controls that and how does it work?
