Old 26-07-2006, 10:44 PM   #1
dsjoyce
Exclamation What sort of EF have i got?
Hey all,
I bought my dads auto EF wagon off him earlier this year and just assumed it was a series 1 GLi. Anyhow my dash has both a volt meter and oil pressure gauge, in addition to the usual stuff, and a mate of mine suggested that GLi's lacked these goodies. It lacks climate control, a trip computer, power windows or any of that fancy stuff. It is however one of the later ones just before the series IIs came out so perhaps ford updated the dash towards the end? Also of interest to me was the fact that its first owner was the SA police department. Being a wagon i very much doubt it was a pursuit car, would it have any extra goodies at all? Mabye a towpack?
Thanks all!
Dan.
dsjoyce is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 10:52 PM   #2
hppsc
Check your compliance plate (passenger side of the engine bay, near the window sill) and check if it says OPT20 anywhere on that plate. If it does, which it most likely will, it is a police order from ford, and the dash you have is a cop spec dash. GLi's do lack the oil abd battery gauges, but cop spec dash's don't.
Also, check the side mirrors. If they have 'Objects in mirror are closer than they appear' etc, it's a series 2 GLi.
Cheers.
hppsc is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 11:01 PM   #3
John_LS1
its possibly a futura. does it have rear head rests?
Old 26-07-2006, 11:06 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
does the cluster have 2 km increments?
futura didnt get the extra guages, only fairmont upwards, could be a cop cluster and maybe a cop optioned car.
as siad, check compliance plates.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 26-07-2006, 11:11 PM   #5
John_LS1
Shows how much i know about EF's :P
Old 27-07-2006, 08:42 AM   #6
Holbrookau
OPT 20
Holbrookau's Avatar
OPT20 (Police Pack) vehicles are GLI based but have a few extras, including:
Sports cluster same as XR except speedo has 2km increments and can be recalibrated in the car.
Uprated ECM (computer) with 230 kmph cut-out and higher auto transmission shift points.
ABS brakes.
Clock.
Mid series BEM (Body Electronics Module) - fade out for interior lights.
Map lights and rear reading lights.
Twin horns.
Lower front springs (XR?).
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2006, 09:22 AM   #7
niko
likes falcon's
niko's Avatar
pics would be nice
www.carhubsales.com.au
Old 27-07-2006, 10:54 PM   #8
dsjoyce
wow guys thanks for all the info!
if you're right Holbrookau it sounds like i've got one tricked up wagon! i checked out the plate this morning and it had opt 10 or 20, i cant recall which. i would check now but my radiator let go on my way home tonight so it's sitting outside kmart tyre and auto. I honestly cant remember what increments the speed do has but i think its 2kph. im almost certain it hasnt got ABS however, at least there is no abs warning light that i can see on start up. is there any way i can check coz im a big advocate of abs so to have it would be cool? Twin horns...what does that mean exactly?
cheers all!
Old 27-07-2006, 11:45 PM   #9
dsjoyce
Ooh and the diff? Would love a 3.45 LSD! Doubt i have it though coz she's a slug off the line!
Old 28-07-2006, 12:25 AM   #10
hppsc
cheers all!
It will have ABS.. Check in the engine bay for an ABS fuse in the fuse box along the drivers side of the engine bay. Failing that, the ABS module should be in front of the passenger side front wheel arch, behind the bumper bar. Kinda tricky to check, but it's there.. Though, if it doesn't say Check ABS when you turn the key, maybe it doesn't have abs?
Twin horns were so the car was louder when in pursuit/emergency. They would help alert upcoming drivers of the cars presence..
Old 28-07-2006, 02:34 AM   #11
Rmyers
Does Steve have a car?
Rmyers's Avatar
As in two horns, you know, beep beep! :P
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2006, 08:43 AM   #12
Holbrookau
OPT 20
Holbrookau's Avatar
You may be lucky and have a LSD (3.23 or 3.45), or maybe it's like mine and is just a 3.23 single wheeler..
Climb under the back of the car and look for tags on the diff housing - should be metal strip hanging off one of the cover bolts which has the serial number and ratio stamped on it. If it is a LSD it would also have a tag under the filler plug which says something like "Anti Spin Differential", and a sticker on the drivers side front pillar saying the same.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Old 28-07-2006, 12:58 PM   #13
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
My mums car has all them options on he cluster (oil, volt) and the rest and a RPM she aslo has a fade out light and a clock its a 94-95 Gli... but no ABS or LSD or 230km cut out unsure about twin horns, no lower front... SO I am confused!
NC_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2006, 12:09 PM   #14
dsjoyce
Nooooo don't say that 6cylEA! I'll have to have a look tomorrow morning - *fingerscrossed*
Old 29-07-2006, 02:32 PM   #15
soulfire
Kermit the Frog
Whoever had it before may have changed the cluster - beware - this proably means the k's on the odometer aren't genuine.
In responce to the original question is has to be a cop pack, or it's had the cluster changed. All models above the gli get front power windows, so that would be the biggest giveaway.
soulfire is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2006, 09:38 PM   #16
dsjoyce
So i had a spare second to myself and managed to squeeze myself under the rear of the car, and found a metal tag as you predicted!
Scraping off 12 years of grime I am greeted with the phrase:
LSD HIGH
PERFORMANCE
APPROVED
Awesome! Now how exactly do i work out what sort of ratio i have!? I couldn't see any more markings but i'll look again tomorrow, and also see about that ABS. No sticker on the pillar either. It's been mentioned here and there that if you ring up or email ford with your VIN they'll give you all the details as it left the factory. Anyone got an actual number or email address for them?
Cheers guys and gals!
Old 03-08-2006, 10:40 PM   #17
Holbrookau
OPT 20
Holbrookau's Avatar
Was that tag on the diff plug? There should be another under one of the cover bolts with the ratio. Don't panic about the sticker, probably just means it isn't the same diff as fitted to XRs (which use a differant oil).
BTW - One thing on my list I forgot, OPT20s should have an auxiliary transmission oil cooler on the auto models. This is fitted in front of the radiator on the drivers side (can be seen through the bumper air intake).
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Old 03-08-2006, 10:45 PM   #18
hppsc
dsjoyce, there's a few ways to check ratio..
- Look for a yellow sticker on the drivers side axle housing on the diff. It may say 3.45
- What RPM does your car sit on at 100km/hr ? 3.45 = ~2000 - 2200rpm @100km/hr
- jack the rear of the car with a trolley jack, and test the ratio by putting a mark on the yoke of the diff, and on the housing, at the same spot. then get someone to turn the back wheels one rotation and count how many times the mark crosses the other mark, then how much past it goes. So, if it'a 3.45, it'll go past 3 times, plus just under a half a turn.
Good luck
Old 03-08-2006, 10:53 PM   #19
dsjoyce
Thanks guys, these new discoveries have got me all excited. I was looking at turfing the old girl and getting a skyline but now i'm tempted to hang onto her. Better look into cams, headers and a zorst!
Old 03-08-2006, 10:53 PM   #20
efgiar
rofl copter
efgiar's Avatar
with an auto it will sit at 2000rpm on 100kmh manual it will sit 2200-2250IIRC with the 3.45 lsd
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2006, 10:56 PM   #21
dsjoyce
I'll check this tomorrow on the way to work, but im wondering does having an aftermarket dual fuel system affect this? I have a feeling my car idles a bit higher than most EFs
Old 04-08-2006, 02:53 PM   #22
ef_classic
ef_classic's Avatar
Mine sits at about 1,700 on a flat road.
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 03:21 PM   #23
Kryton
Kryton's Avatar
so does it say OPT20 or not?
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 05:40 PM   #24
AshMan
Girrrrr!!!
AshMan's Avatar
Ring ford and quote the VIN number for a definative answer.
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2006, 05:47 PM   #25
efgiar
rofl copter
efgiar's Avatar
prolly a 3.08 diff
GQ patrol.
thats all
Old 04-08-2006, 11:22 PM   #26
dsjoyce
Ok well mine sits pretty much dead on 1800 on either petrol or gas...is this good or bad lol? And yah tis an OPT 20. Also i had a look and yup, i'm packing an oil cooler for the auto Still trying to figure out the abs though. I mean surely if it had ABS, there would be an abs warning light in the dash. No ifs, buts or maybes. So i guess i just answered my own question hehehe
Old 04-08-2006, 11:25 PM   #27
Kryton
Kryton's Avatar
try looking for the ABS fuse, if its been pulled it may not show on the dash???
Old 04-08-2006, 11:53 PM   #28
dsjoyce
I had a look in the fuse box in the engine bay on the drivers side, and buggered if i can tell what's fused and what's not. I've not seen fuses like that before! It seems to have a big square something in it, but im not really sure if it's actually fused or not. I'm useless when it comes to stuff like this, i know :P
Old 05-08-2006, 01:10 AM   #29
Holbrookau
OPT 20
Holbrookau's Avatar
The square things are relays. Try the fuse box (in the car - lower right hand side of the dash). ABS power comes via the Auto TX fuse, which also runs the Air Bag and thermo fans..
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Old 05-08-2006, 09:25 AM   #30
Holbrookau
OPT 20
Holbrookau's Avatar
Please ignore the above post - not sure where I was going with that one..
The main ABS fuse is in the rectangular fuse box located under the bonnet, beside the coolant reservoir - it's marked as ALB. These are fuses, just a different type than you're used to, and should be obtainable from most auto parts stores.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
