Old 12-08-2013, 01:41 PM   #1
4ford
Default Replacing the accessory drive belt and tensioner pulley
Gents . . .
I've recently noticed that the cam tensioner adjuster is leaking oil in my AUII 6 (non VCT), so have decided to fix it at home. I have a couple of questions:
1/ Which is the best brand of drive belt, and where
2/ Which are the best idler pullies to buy, I've seen them at around $23 in Super Cheap, but am suspicious of their quality.
3/ Simply removing and replacing the cam tensioner, to seal it from oil leaks, will that have any unintended affect on the actual tension applied to the cam?
Thanks
Last edited by 4ford; 12-08-2013 at 01:42 PM. Reason: Overlooked mentioning the engine size!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2013, 10:11 AM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: Replacing the accessory drive belt and tensioner pulley
G'day 4ford,
1) Gates are pretty good brand of drive belt
2) go a metal instead of a plastic pulley but have not seen a plastic pulley disintergrate either.
3) have a look at this thread with some great how to's,
http://fordforums.com.au/showthread.php?t=11336109
cheers, Maka
Old 13-08-2013, 08:58 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I forgot about this one
UK
