26-10-2009, 08:26 PM | #1 | ||
Hey guys, it's been ages since i've done a post on here!
I've got 2 rear door trims i bought off a member on here that came out of a wrecked AU3 XR8. Apart from the switches i would need...how much other stuff do you need for it all? I will be getting my auto electrician to install it all once i have everything. Cheers. |
26-10-2009, 08:34 PM | #2 | ||
you can get proper looms for it, probably from a wrecker, but that's up to you. you will obviously need the 4 way driver's door switch and motors for the rear windows. apart from that there's not much to it. i did a 4 power window conversion in my au1 forte that only had manual windows and it wasn't very hard to do at all. all i did for wiring was, down driver's kick panel, into rear driver's side door, and passenger was under dash and down to rear passenger door.
26-10-2009, 08:35 PM | #3 | ||
Window regulator/Motor and rail. As above, Wreckers will have the looms.
AU XLS. |
26-10-2009, 09:24 PM | #4 | ||
You could try doing a search...
http://www.fordforums.com.au/showthread.php?t=11241112 http://www.fordforums.com.au/showthread.php?t=11221199 Plenty of other threads, thought I'd just go with the ones you started |
