09-02-2012, 08:04 PM | #1 | ||
Throttle hang + Poor mileage + loss in power = Vacuum leak.
After doing such and extensive work on engine I was thinking what could possibly go wrong in near future? Well, its hardly a month I had good time with my kat without any hassels. Now there is a vacuum leak somewhere thats drawing excess air while idling causing rpms go over 2500. Searched everywhere for leaks but no luck. I could hear the leak but couldn't find where. Wasted a spray can of contact cleaner but couldn't trace the leak. By passed oil catch can but didn't make any difference. I don't know if it is co incidence or consequence day before yesterday I found instrument cluster and dvd player were reset on its own. Then after a while it happened again. After a bit of investigation I found the accessory cable on positive battery terminal was loose. I couldn't figure out how that happened. Couldn't make it tight or loose. Eventually I snapped the bolt and bolted that cable on the main bolt that locks terminal onto battery. Since then idling has changed. Every time I depress clutch or shift to neutral rpms goes over 2000 and drops down after few seconds. Mileage has gone from 8.9L to 14.5L. Replaced IACV and disconnected TPS plug while engine running which didn't made any difference. I think its time to strip things around engine..
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can. Now driving a Lexus RX 450h. Your guess is correct that I am a family man now. |
10-02-2012, 01:30 AM | #2 | ||
Hey Yogi,
Sorry to hear about your troubles there! That's a hell of a blow out on the mileage. Here I thought I had my own lil gremlins to deal with occasionally but seems one has cropped up into your engine bay too now! Well at least with you personally having recently stripped the engine right back, you'd be in the best position to hopefully identify where this problem lies or has come on from after all... Best of luck with it and here's too a speedy recovery back to the good times again! |
10-02-2012, 08:22 AM | #3 | ||
Probably wrong but is your air flow meter playing games? just a thought
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
10-02-2012, 08:54 AM | #4 | ||||
10-02-2012, 03:31 PM | #5 | ||
If you have a vacuum leak you can bet it will be the source of ALL your troubles.
Find the leak and you will be OK. I sprung a leak one day on the Harbour Bridge and was lucky I wasn't killed.
Owning a Cougar is like owning a Super Model Good to own but "High Maintenance" 2000 Model Eibach Cougar (Auto) - Now dead & buried |
11-02-2012, 02:31 AM | #6 | |||
I know that theres vacuum leak on my kat as I can hear it and there is throttle hang as well. So, I tried to wiggle and later pulled all vacuum hoses to see if they are loose. One of the hoses didn't feel alright so, pulled it a just a bit hard and it came off. It was partly holding and partly off. This was the culprit. The vacuum hose that was off. It runs along firewall behind engine and connect to HVAC that is mounted on firewall. On some kats it is mounted in UIM. Its hard to see it and accessing it is far thing. Fixed that hose and everything is back to normal. No throttle hang, no over revving, no leak sound. Reset the ECU so that it forgets that it use to and has to pump extra fuel. What a relief... all happies now
