Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 01-03-2014, 01:10 AM   #1
russellw
russellw's Avatar
Default OE Replacements
I've not been particularly happy with the OE dampers on the FGII EcoLPi XR6 - most of my daily commute is on fairly ordinary roads and the front and rear ends didn't feel particularly well in synch with each other and the car has been generally floaty and inconsistent in handling. Could excuse both of those if it had a nice ride but it was easily upset by low amplitude bumps and really only liked mirror smooth surfaces - which Victoria is notoriously short of!
After a couple of chats with Brett at Shockworks, Chris and he kindly fitted a set of their OE replacement dampers today and they have quite seriously transformed both the ride and handling of the car.
The two ends now feel like they are on the same page and while the ride is a little firmer it is also much better controlled and certainly nowhere near anything that could be called even vaguely harsh even on corrugated gravel surfaces.
It's always interesting to meet and talk to people who know their stuff the way these guys do and while I'm happy to profess I understood only a small percentage of what was said it is clear that their commitment to testing and researching for solutions sets them apart.
I'll provide more of an update after I've run a couple of thousand on them but I'd certainly recommend these to anyone looking for improved ride and handling without going the whole adjustable coil-over route.
Russ
Old 15-07-2014, 09:15 AM   #2
Dash_XR
Dash_XR's Avatar
Default Re: OE Replacements
Any update on this Russ? Happy Birthday btw too mate.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2014, 06:41 PM   #3
russellw
russellw's Avatar
Thanks. They have certainly sharpened up the handling significantly and I am pleased with the results. They can be a little harsh on some of our larger corrugations but the guys are going to try a small change next time I am out that way.
Russ
Old 15-07-2014, 07:01 PM   #4
Dash_XR
Dash_XR's Avatar
Yeah had a brief chat with Brett today and he was very helpful, even though they aren't adjustable they should work well with the ride hight I'm after so will be getting a set when I get my tax back.
Plus I like the idea of supporting local companies wherever possible and actually having them local is even better.
