[EBGLT]
It might be a dumb question but how do i hook up my vacuum gauge?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
which one do ya mean the one that gives you manifold vac? find a outlet on the carb if there is none spare splice one in to it like get a t joint to go in
#3 | |||
Thumbs up for fossil fuel
Yep, the T piece is the go. Simply splice it into one of your small diameter flexible rubber vac lines. These originate at the back of the inlet manifold's plennum (chunk on the bottom that your throttle is bolted to). There should be a plastic 'tree' at the back there with quite a few lines coming off it. As far as I know, any of these will do. I said the small diameter lines because the two larger ones are for Brake Booster and MAP sensor. A T peice should not cost more than about $2 from supercheep and I think that vac hose (to run to your guage) is around $1.20/metre. I like to use small cable ties around the hoses at vacuum junctions just to make sure they never come apart. (Think of them as a small hose clamp). Hope that helps. Mike
God created F-trucks so that you could put their engines into E series. 1992 EB Fairmont 351cu in Windsor Roller Cam Valve Body "Shift Kitted" BTR 4spd Auto Hi Tek Headers Tri Y Twin 2.25 into Single 2.5in 17in x 8in BA XR8 Copies 235x45x17 Nankang NSII Ultra Low King springs Whiteline 30mm Swaybar Nolathane box section trailing arms Slotted DBA front rotors Yella Terra roller rockers |
[EBGLT]
Sweet as boys thanks for that ill try get onto it before the christmas party tomorrow!
