10-04-2012, 01:09 AM | #1 | ||
Hey guys need help urgently. changed the trans in my au with another one from
my old au which i know works. we used the torque converter from the old one aswell. gave it a service and put it in. now it does sweet f.... all. put it in reverse and it move ten feet maybe and in drive i got it around the block but no faster than 20kmh as its just slipping. Really could use some help on this one cheers jason
Current Cars - 82' Twin Turbo RA60 Celica - 82' Hills Weapon RA60 Celica - 82' Stock RA60 Celica - 99' AU1 Futura - 96' EL Fairmont Previous Cars - 11x 82-85 Celicas - RA40 Celica - MX83 Cressida - RT104 Corona - XE Fairmont - XE S-Pack - XF Falcon Manual - Datsun 200b - Camira Wagon - Hyundai Lantra |
10-04-2012, 01:11 AM | #2 | ||
Im going to ask the obvious, how much fluid is in it?
10-04-2012, 09:00 AM | #3 | ||
We put oil in it until it came out of the hole on the side. it wAs in the air and even.
Does the oil have to settle then chhseck it again?
10-04-2012, 09:19 AM | #4 | |||
Au Falcon = Mr Reliable
Yes, fill until it stops running out filler hole, then run through gears, then recheck and top up. Do a search if your stuck, many members have done this job succesfully.You got a workshop manual? cheers,Maka
10-04-2012, 11:33 AM | #5 | ||
Yes, you can't just fill it with fluid first time around and leave it at that.
You must fill it up initially to full then start and run through gears (standing still) for a few minutes then fill again - might take another 2 litres then no harm in driving around the block a few times and checking (and possibly topping up) a THIRD time... might take another 500ml. That's what I did. |
10-04-2012, 09:56 PM | #6 | ||
that's the norm mate, you never get it full with one pan full, you have to keep topping it up after running through the gears engine running.
11-04-2012, 08:20 AM | #7 | |||
