05-07-2022, 09:37 PM | #1 | |||
mechanical novice hopeful
On removing the wiper nozzles from the bonnet/hood. Yes removing at least some of the hood liner clips is a good idea.All the plastic parts are pretty old and brittle now. First I removed the lines. Which did not want to come off. But after wiggling in the smallest flat screw driver a bit they did. Yes the nozzles are just held in by 2 plastic clips that need to be pressed and the nozzle popped out upwards. But I was confused as to where to squeeze. The plastic protudences from left to right across the bonnet, are actually just locators/stays, which fit in slots in the hood. The 2 plastic bits you want to press to pop out run up and down the bonnet. Hope some of that might make at least some sense :p And yes, the clips do tend to break under hood liner, even using the correct upholstery removal tools (if you are patient and wiggle them around a bit as you pull, you can seem to reduce the amount of breakage). Fortunately you can still buy them for a reasonable price from Car Parts Clips and Fasteners (I found them very helpful).I chose to use Toyota ones and save a few bucks; - Ford OEM Part Number V-860346-S300. CP0960245 Black x10 $38.50. Proudly A High Quality Australian Made Genuine Ford Part! Ford Falcon Fairmont XR6 XR8 Models AU BA BF FG. Ford Territory All Models. SX SY SZ. Head diameter 30mm. Hole size 6-7mm. Stem Length 16mm. - Toyota OEM Part Number: 90467-09006 9046709006 Toyota and Lexus bonnet hood insulation retainer fastening clips. Toyota vehicles commonly used on: Prius 2003 to 2011 Celica 1982 to 1985 Corona 1992 to 1997 Camry 1983 to 2006 Cressida 1988 to 1993 Avalon 1995 to 2005 Avensis 2001 to 2009 Tarago 2000 to 2006 Landcruiser 1984 to 1989 & 1998 to 2007 Hilux Surf 1995 to 1997. Lexus vehicles commonly used on: ES300 1992 to 2001 LX470 1998 to 2008. To Fit 6-7mm Hole. Head Diameter 29.5mm |
