12-02-2007, 01:00 PM | #1 | ||
I just got to work and noticed that my rear tyres are stuffed, in fact one is so bad it looks like if I drive on it again I'll delaminate it.
Now the question is, can I run a set of 205/60's on the rear without any ill effects? Thanks for your help Curare |
12-02-2007, 09:36 PM | #2 | ||
Over Thinker
you can only run the tyres specified on the tyre placad /sticker
should be under the bonnet in the glovebox or on a door frame/ask a tyre supplier
My car goes Brumm Brumm |
13-02-2007, 12:01 AM | #3 | ||
I also have trouble with rear tyres on the AX. In the past I have delaminated to the steel belts. I found the rear rotors warped when I took them off and lay them on flat concrete. New rotors seem to have solved the problem and rotate the tyres regulary.
14-03-2007, 04:34 PM | #4 | ||
In the family since 1996
205/55/15", toyo had a good tyre out a few years back when i had a tx-5
