14-03-2021, 07:46 PM | #1 | ||
Can anyone enlighten me what size rotors are supposed to be for the LT '07 Diesel? Also are the pads DB1679?
The workshop manual (available here) says its 300mm but every eBay or other online listing is saying its 278mm, confused |
15-03-2021, 10:03 AM | #2 | ||
278mm is the size for the 1.6 and 1.8L engine models according to the LT WSM.
I believe the pads are DB1679 for the front and DB1763 rear. The replacement front rotor should be a Bosch PBR2380 or DBA 2118E.
15-03-2021, 10:22 AM | #3 | ||
Below are the specs for the brakes, how ever its confusing as the parts catalogue only lists one rotor for all?
Genuine Rotor: 5M512C375AC Genuine Pads: 7M592K021AA LT Focus Front Brakes.JPG |
15-03-2021, 12:55 PM | #4 | |||
15-03-2021, 01:02 PM | #5 | ||
I would like to check something, would you be able to supply your VIN..
15-03-2021, 01:23 PM | #6 | ||
17-03-2021, 09:16 PM | #7 | ||
I am confused also I have a LS 2ltr Ghia sedan made in South africa and every thing is different including LHD headlights could you please let me know what front and rear disc rotors I should buy I get told 278 all round and also get ones that fit thanks
18-03-2021, 10:19 AM | #8 | ||
I had a LT tdci made in South Africa and it had the 278 rotors
18-03-2021, 11:20 AM | #9 | ||
LR Front
300 mm – vehicles with 2.0L Duratec ST 258 mm – all others LR Rear 280 mm – vehicles with 2.0L Duratec ST 252.7 mm – all others Some LS/LT models were equipped with 203 mm drum brakes on the rear. LS/LT/LV Front 300 mm – vehicles with 2.0L petrol engine or 1.6L/2.0L diesel 278 mm – vehicles with 1.6L/1.8L petrol engine 320 mm - LV Focus 2.5L Duratec-ST only 336 mm - LV Focus 2.5L Duratec-RS only LS/LT/LV Rear 280 mm – vehicles with 1.6L diesel, 1.8L diesel or 2.0L engine 260 mm – vehicles with 1.6L or 1.8L petrol engine 280 mm - LV Focus 2.5L Duratec-ST 302 mm - LV Focus 2.5L Duratec-RS only Some LS/LT models were equipped with 228 mm drum brakes on the rear.
18-03-2021, 01:02 PM | #10 | ||
thanks very much for that Russell...keep up the good work for all of us dumb oldies
30-03-2021, 08:28 PM | #11 | ||
Well I finally got them checked and they're 278mm on a 2.0 Diesel so something is wrong somewhere. Perhaps the 300mm was an optional upgrade?
