Old 05-08-2008, 06:57 PM   #1
TX3
Rally hard
Default tx3 4wd turbo clutch slip & cut out prob
Hopefully someone can give a bit of advice. Have a turbo 4wd with clutch slippage. Took off from pub t other day felt a slight pop in clutch pedal then severe clutch slip. Have removed clutch and found crack in the clutch plate where one of the springs r housed.looks fairly recent.Could this b the cause of the slipping. Also got a prob with the car cutting out on corners.Runs pretty well
otherwise except can only run shell fuel. the cutout happens more on left than right hand corners. Any ideas cos its got me stumped cheers
TX3 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2008, 09:14 PM   #2
TX3
Rally hard
turns out its the centre diff so jf anyone out there thats got a copy of the tx3 supplement so that i can attempt a rebuild it would be much appreciated
