Am going to flush out the radiator. I'll be using one of the corrosion inhibitors when refilling it. I know distilled water is no doubt the best option, but with the inhibitor, will tap water be fine? Cheers.
Yes it will be fine, unless your water has a high amount of deposits.
Eg: Adelaide water....
I use premixed coolants in mine, because they have no Adelaide water in them.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
#4 | |||
Back to Le Frenchy
Or worse, Ballarat water. If it's Melbourne water you will be fine though.
![]() Join Date: Dec 2004
I use distilled water. Cheap as from woolworths.
#6 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Free tap water...? no at my joint...worse than power/gas down my way.
JAIKAI
86 XF wagon:future mods-4spd, CAI. 04 Camry Sportivo with the lot:future mods-dont need any... |
#8 | |||
bettering 13.7
best off using distilled water, the less contaminants/minerals and chemicals the lesser the risk of corrosion/scaling from happening. at a bare minimum use filtered water.
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer FPV/Tickford Club of W.A Performance is Electronic BPT Motorsport |
As a diesel fitter. Id recomend you use a premix coolant. Tap water it tricky as you never really know whats in it. Even to much chlorine is harmful to alloy componants.
need more boost
Pffffft, I used water from our dam (not a big river dam, a small muddy hole in the ground country style dam) with no 'real' coolant in it for a couple of years. Coolant is overrated.
Except on the 5L's, they corrode rather fast for some reason, especially waterpump housings ![]()
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#12 | ||
Have you ever rebuilt an engine? Coolant stops the water from cavitating around the water pump and bores in the cooloant channels(It lowers the density and friction). I have seen cavitation damage done to blocks where they have been that badly pitted from using "dam" water that they leak coolant inside the boars. Coolant also makes the boiling temp alot higher. But mainly coolant or dca should be used as it protects the engine from cavitation aswell as corrosion
distilled water for batteries, tap water for radiators.
#14 | |||
need more boost
#15 | ||
Demineralised from Big W
$2.50ish for 4 ltrs I use tap water for the holdens and cast heads.
CareFree.... we may not be No.1 but we're Up There |
#16 | |||
#17 | ||
Well, I used normal water. It was fairly dirty, and had very little coolant left in it. Can't be any worse. Is now reasonably clean with a new lot of coolant.
#18 | |||
#19 | ||
What happens if you mix all 3, I have to admit that I have done it, aaaand then there is supposed to be the alloy head. ? Adelaide water.
#20 | ||
I use rain water.
And Tectalloy Gold Concentrate, 1lt makes 15lts. |
#21 | |||
