Old 22-02-2024, 03:43 PM   #1
malbaby
Default 302 Windsor into an ZD Falcon.
Hi Guys,
Seeing that the V8's only came from the factory as Clevelands...would I need an engineer's certificate to install it into a factory 6cyl car?....in Victoria
malbaby is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2024, 03:59 PM   #2
Dr Terry
Default Re: 302 Windsor into an ZD Falcon.
Are we talking ZD Fairlane or XD Falcon ? Typo ??
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 06:59 AM   #3
malbaby
Oooops...XD Falcon.
Old 23-02-2024, 08:02 AM   #4
EBSXR6
Originally Posted by malbaby View Post
Hi Guys,
I believe the car would need to pass an Emissions Test.
From memory I believe ADR27A is the relevant design rule for an XD era built vehicle.
If the 302 Windsor is from the late 60's I think it would be pretty difficult to get the engine to pass the emissions test.
I don't know if this is an urban myth, I read that if you fit an engine designed for a later model car to an older car the car has to pass the emissions regulations at the time of the engine manufacture.
If the Windsor engine was built for a Car from the EB to AU era then your XD would have to pass the relevant emissions test from that era.
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 11:54 AM   #5
ozpacman
Thinking about this, I seem to think it might be the other way around. The car body is fitted with the compliance plate which stipulates what ADR's the vehicle was built to comply with. Wouldn't it be the case that the fitting of a later model engine would therefore mean that it would only have to comply with the ADR's for that car as per the compliance plate?
ozpacman is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 07:13 PM   #6
foxtrot3
foxtrot3's Avatar
Hi. The engine has to comply with the emissions for the engine and has to be the same year or later than the car and evaporative emissions (fuel tank venting) need to comply with the age of the car and an engine from an unleaded fuel car needs to have a fuel fill pipe that will only take an unleaded filler. it would also need an exhaust catalytic convertor or 2. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 07:47 PM   #7
jpd80
jpd80's Avatar
In the end, it might be easier to sell the Windsor and just put together a nice Cleveland for the car
with all emissions and Thermoquad to get past the emissions declaration as it was legal engine option
for that vehicle. Some uploaded Ford manuals here on the site under Tech Resources guide you.
If you’re determined to go the Windsor route, maybe talk to an authorised engineer first before
you commit too far, they might also offer some good suggestion on what to do to comply and get more power.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2024, 08:55 AM   #8
malbaby
Thanks guys...very helpful.
Old 25-02-2024, 02:37 AM   #9
XP6
Formerly ST170ish
XP6's Avatar
Correct, except the filler pipe that was only in place until leaded was phased out.
Mal, is it a old school 302 or 5.0?
If Im remembering correctly the 5.0 inlet manifold fowled on the heater pipes or something like that.
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!!
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2024, 09:42 AM   #10
malbaby
Same as me old skool.
