Old 28-01-2022, 09:43 PM   #1
bundybear75
bundybear75's Avatar
Default Removing ball joint
Hi Brains trust...
Does anyone know how to disconnect the b****y tight ball joints from the steering knuckle?
I have tried all the tricks. Hammering the knuckle. A ball joint separator. Even resorted to the ball joint wrecking wedge tool.
I cannot get the stupid thing to let go.....
Any hints??
PS - I have undone the nut 🤣
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2022, 09:47 AM   #2
russellw
russellw's Avatar
Default Re: Removing ball joint
There's a couple of YouTube clips showing a hydraulic jack being used so maybe that's a last resort!
Old 29-01-2022, 10:26 AM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
bigger hammer, I used a 4lb hammer to really thump it (wedge tool), and then hit the knuckle and it popped out. I should mention I'm not scared to wield a hammer but I know how to handle one too.
the other trick is to use heat on the knuckle side of the tapered hole and hit it. The heat on the knuckle will open the taper, hopefully helping in releasing the tierod end when hitting it some more blows.
lol you can see why i removed my lower control arm when doing my suspension all those years back. It's tight as all buggery.
Undecided replacement...
Old 29-01-2022, 04:06 PM   #4
bundybear75
So I ended up removing the wishbone and knuckle, drilling out the rivets, then using the ball joint separator and a rattle gun, loaded the ball joint right up, then smacked the knuckle again with a hammer.
Ball joint exploded out of the knuckle, never to be seen again ������
Next problem. Pressing out the bearing. My 6 tonne press isn't up to the job. Any suggestions what size press I need?
2002 BMW R1150GS
Old 29-01-2022, 05:48 PM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
10t would do the job but might be best left to a workshop, so get the other side ready to go too, then pay once for the press.
Paying for a workshop to press some things is one job I'm happy to pay, especially if I'm not doing jobs that require a press often. Even if it sucks having to get into town to get it done.
Old 30-01-2022, 03:19 AM   #6
You usually replace the whole lower wishbone arm as an assembly see https://www.ebay.com.au/itm/33430174...AAAOSwR7hh7OZP and https://www.ebay.com.au/itm/33430550...frcectupt=true and https://www.youtube.com/watch?v=OyO6qp0Uyes
Old 06-02-2022, 10:27 PM   #7
Romulus
Romulus's Avatar
I've just bought a 2017 MD Titanium auto diesel hatch with just over 55k's on the odo. I'm going to have my local mechanic do a full inspection on it but just wondering, are the ball joints and wheel bearings a problem on these vehicles?
TIA.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock
Romulus is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2022, 01:43 AM   #8
cobrin
Challenge Accepted!
cobrin's Avatar
No they should last their typical service life given it's been treated normally.
Old 13-02-2022, 07:40 AM   #9
NZ XR6
Bundybear, did you get this sorted?
Sent from my SM-G980F using Tapatalk
Old 13-02-2022, 12:11 PM   #10
bundybear75
20 tonne press made short work of the bearings. Unfortunately, it didn't solve the suspicious noise from the front end. I have an awful suspicion it is in the gearbox somewhere. I need to get it up on a hoist, and try to pin down the noise
2002 BMW R1150GS
