Old 18-06-2006, 03:20 AM   #1
Growler
Growler's Avatar
Arrow EF's over long periods of ownership
My mate has an EF, when he purchased it over six years ago it would do some serious standstills with a single spinner on racing tracks etc. : but now he has problems getting the things to spin like they used to, he has put on 18inch rims and that's why he can't light them up, but on the weekend we put stockies on the back and he tried to light them up in my backyard on concrete and all it was doing is revving and no wheelspin?
In the dissapointment of this occurance i drove my Dev5 powered EF wagon out the back and that had no probs at all for very obvious reasons :king:
Could it be his diff that is now old and not ripping standstills or 'burnouts' as some call them. What would you suggest he do without going into modding, add turbo/blower etc.
Growler is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 04:09 AM   #2
EFFalcon
Last warning
EFFalcon's Avatar
worn rings, lower compression, less downlow power.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 18-06-2006, 04:14 AM   #3
Growler
Growler's Avatar
And the solution for this is _________. < please fill in.
Old 18-06-2006, 04:18 AM   #4
EFFalcon
Last warning
EFFalcon's Avatar
I guess a compression test or leakdown test would give an indication of the bottom ends condition.
over time things just wear out, weather it be fuel pump, filters (fuel, air), engine.
Engine temp can also have a big influence on the power, as it air temp.
Old 19-06-2006, 12:02 AM   #5
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
my stock(engine) ef s/w is quite tempromental when it comes to plant both feet. same problem? its on 17's and one would think the slicker surface of the dunlops would make it easier...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 11:05 AM   #6
niko
likes falcon's
niko's Avatar
when i 1st got me el as an auto, that was the 1st test i did, with a 15" stockie and then a 17" rim and it spun both as easy as the other
www.carhubsales.com.au
Old 19-06-2006, 12:11 PM   #7
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
same here, when i first got the ED is was easy, now it won't unless the road is wet
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 05:37 PM   #8
efgiar
rofl copter
efgiar's Avatar
single spinners are easy to spin, wen u get an lsd with an auto it might struggle, but with a single spinner and it doesnt spin em on a stocko, compression/low down power will be cr4pz0r as john mention
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
