15-05-2013, 06:29 AM | #1 | ||
10 year ago my uncle fitted his EA SPAC with nolathane red bushes all round. has only seen the track about a dozen times and has sat idle for 4 years. when I started checking all the driveline suspension (nut an bolt check) worn parts etc, found the swaybar bushes were crumbling and near gone. ive had 23 years in the xr8 with the standard black bushes so have the nolathane bushes have a useby date .
15-05-2013, 07:59 AM | #2 | ||
I had poly bushes in my rear control arms of my EB but they lasted about 1 month, got onto the company they kept sending me more for free but they didn't last so in the end they send race quality parts but i sold the car without fitting them. next time i will just use rubber ones.
EB was a turbo V8 so had a bit of torque handy. I have use poly in my old patrol with leaf springs and that squeaked all the time even after using the correct grease.
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
15-05-2013, 08:21 AM | #4 | ||
Cheers for the replys guys. sittin around sure is a killer then . used superpro in the wifes xr6 and it seems ok after 3 1/5 years now. but as im using this car for track an hillclimb I wanted to use nolathane .
15-05-2013, 09:06 AM | #5 | ||
If they get contamintated with oil fuel etc,if they do they break down real quick.
15-05-2013, 10:43 AM | #6 | ||
Ive found if they are fitted at ride height and lubed prperly they last for ages IF the car is being used, for some reason thogh if you park the car up for a while they'll crumble as soon as you start usning it again
I have to say I prefer rubber as a personal choice though
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
15-05-2013, 03:35 PM | #8 | ||
I'm a bit of a factory rubber fan myself, still have all of the original bushes in the au except for what came with konis, 12 years still in service hard to beat.
15-05-2013, 09:41 PM | #9 | ||
Performance moderator
Replace mine every two years..
15-05-2013, 10:49 PM | #10 | ||
I fitted Nolethane bushes to my XM in 1987, they were ok for about 20 years before they started to crumble. I replaced the last of them last month with blue Superpro bushes.
I think I will crumble long before they do.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
17-05-2013, 12:34 AM | #11 | ||
You will be hard pressed to beat rubber bushes, they will last longer and be a better ride with less squeaks and rattles.
I avoid the Nolathane and similar as much as possible.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
17-05-2013, 10:25 AM | #12 | ||
Now in the quad cam zone
im about to install nolathane again into my XA with my new suspension, i want to try the nolathane with the new springs and setup, if its too harsh etc i'll use rubber.... thing im worried about is they done give you enough grease with the nolathane, what type of grease is it and where can i get some more of it?
SOLD! "BARNEY" 2003 BA GT #332, Phantom, Boss 290, FR20 Simmons. XYZ Brakes - 355mm Rotors - 8piston Front Calipers & 4piston Rear More Mods soon!! |
17-05-2013, 10:31 AM | #13 | |||
19-05-2013, 08:35 PM | #14 | ||
I think if you are fitting the urethane bushes you are looking for increased stiffness. I am looking for that and would be prepared to replace them more regularly to keep that stiffness.
The rubber ones appear to last a long time but how long do they keep their factory stiffness? Bushes on a car a consumable that needs to be replaced as required. |
19-05-2013, 09:28 PM | #15 | ||
Back '87 when I was punting an EA around Lakeside, the original rubber bushes lasted a few laps before they were cactus. I put Nolathane in and they lasted till the car died.
19-05-2013, 09:29 PM | #16 | ||
GTP-RPD
Got nolathane on the top arms of the ED. Squeaky and creaky as hell. Going to go for the super pro for a change Heard they are better. Any thoughts guys, I have been told they are more aligned to rubber. Not as hard as nolathane.
20-05-2013, 08:05 AM | #17 | |||
Au Falcon = Mr Reliable
cheers, Maka
21-05-2013, 04:16 PM | #18 | ||
Hi all,
We seen this post and thought we could answer some questions to the forum users. First of all an easy answer to the grease question, we do supply grease but you can use any lithium or molydenm base grease (basically what they use in CV joints ). About the harshness over rubber . There are different versions available on certain models but on average we use 75 duro and that is not much firmer than rubber . Allot of what we are reading is about many years ago when urethane technology was new and yes in some cases quite firm. We did notice a few posts about sitting the bushings and crumbling. This is a thing of the past from many years ago when the product was first developed. Nolathane and other companies got the technology from overseas and did testing on many cycles and in cars to see its durability. no one thought of actually just sitting it not used as the parts we sell are for moving parts in a motor vehicle. The crumbling mainly occured from cars sitting in sheds not being used and more often humid conditions. Since this time urethane technology has changed to be stronger, softer and smarter and we use a different formula that imitates rubber in ride quality but is allot more durable . The new formula will not crumble and we are now that confident we introduced a lifetime warranty for the time you own the car. For a restorer this would be a very long time so you can be confident! Check out the warranty policy here http://www.nolathane.com.au/warranty_register.php. If you have any further questions or would like to know more about the product please email us sales@redranger.com.au as we are not on here too often and the email will be answered within 24hrs except weekends Thank you |
5 users like this post: |
21-05-2013, 04:20 PM | #19 | |||
Try lithium or moly grease that is dark gray (the grease used in CV joints ) as this usually lasts for very long periods if not the life of the bushing |
21-05-2013, 04:26 PM | #20 | ||
Is that grease OK to use with Nolathane bushes? Good to know.
I love Holdens.... |
22-05-2013, 06:58 AM | #21 | |||
22-05-2013, 07:57 AM | #22 | ||
22-05-2013, 08:00 AM | #23 | |||
Drop us an email and we are sure we can replace these bushings with the new formula for you. Either way we can explain further and or give you something for the inconvenience of the old design. No need to apologise we like the feedback positive or negative thank you. |
22-05-2013, 09:26 AM | #24 | |||
cheers, Maka
22-05-2013, 05:58 PM | #25 | ||
After reading through the op again, yes it seems i'm now one of the hundreds of people who have mixed up Nolathane with any old automotive urethane bushing product. My apologies to Nolathane for the faux paus!
cheers, Maka
