low wagooon
Hey guys just wondering where is the easiest path to run my wiring for the amp? Ive got 4 gauge wiring and its a 1996 Ef Gli.
Webby
S2 AU XR6 UTE |
ORSM Ford Cruisers
hey. i have 8 guage so its a bit easier to bend but anyway. my car is auto so i just used the hole already in the firewall the goes directly into the driver footwell. i then took of the drivers kick pannel and the plastic parts on the bottom when you open the door. i then lifted up the carpet and lay the wire under that. i then took out the back seat and then thread it through the boot removing the appropirate plastic bits.
also i ran my rca and speaker wire on the opposite site of the car. hope that helped any more info send me a pm matt
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
low wagooon
Oh ok mines auto so there will be a hole for the clutch cable thats not in use. Was it a tight fit with the 8 gauge wire?
Webby
S2 AU XR6 UTE |
#4 | |||
ORSM Ford Cruisers
low wagooon
Ok sweet thanks heaps man
Webby
S2 AU XR6 UTE |
Aspiring mr efxr
i have 4 guage (power and ground) running from the battery, throught the firewall throught the accelerator rubber (had to drill rubber out) straight up the middle of the drivers seat under the rear seat and up between where the seats fold. all under the carpet ofcorse.
for speaker wire just run out the back of the dash and down under the drivers footwell carpet and under the sills, up the side of the seat then whereever u need to go. the side panels in the boot are on clips up the top of them so once u take the screws out at the tailgate and remove C pillar trim its all too easy to get to the tailgate! if u take the power route i did ensure u run ur RCA's down the passenger side of the car as u will get interference as i have got :(
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
Power down drivers, RCAs and speakers down passenger side or either side of trans tunnel if you want.
