Old 14-08-2011, 11:10 AM   #1
montyLalor
Padawan Learner
montyLalor's Avatar
Default AUII Cluster Chimes on Occasional Startup
I've just recieved my first ever company car with a new job. It's an AUII Ute.
It has a curious set of instrument cluster chimes upon startup sometimes. Two (maybe three) sets of 3 assending sounds. It is actually the very chime-set that my EL GLi does when I shut-down with headlights on. "Do Da Ding - Do Da Ding" The difference being the AU does only two or three repeats wheras the EL only stops repeating when lights are switched off.
So far I've asertained that it generally only happens on a cold start.
The AUII ute came with a Max Ellery's but I cannot find a list of dash chime warnings and it has no owners manual in the glovebox.
Any ideas?
Daily: 01/12 FG MkII
G6 ECOLPI
Your fronter manoeuvres with the eloquence of a fiery wall of disintegrating fuselage...
montyLalor is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 11:20 AM   #2
zlcrazy
zlcrazy's Avatar
Default Re: AUII Cluster Chimes on Occasional Startup
Any ideas?
Hi
Are the doors closed when this happens???
May be the door ajar warning.
Zlcrazy
2005 BAII Falcon XR6T - Velocity Blue
Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim.
Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder.
[B]2000 AU2 Fairmont Wagon - Congo Green
Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps.
zlcrazy is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 11:37 AM   #3
Jim Goose
If the DTE (distance to empty) is below 80km it will chime as soon as you turn key to remind you it needs fuel... it also chimes again at 40km DTE... and then 20km....
There is also a speed alert chime (look for an S in a circle in the LCD display) which i think comes on as well to say its active
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 12:14 PM   #4
EATHSV
Oo---oO
EATHSV's Avatar
sounds like low fuel warning to me. Push your trip meter to change between distance traveled and distance to empty. (dte) as mentioned above it'll first chime when the car decides that you only have a range of 80kms left in the tank. Again at 40 and 20.
nothing to worry about mate.
AU2 Fairmont Ghia - Monsoon Blue, TS50 wheels -ongoing project.
Successful transactions with the following members:
Ride, Raised by Monkeys, TICK4D-TAS, Falcman007, 2002AU, JC.
EATHSV is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 01:01 PM   #5
montyLalor
Padawan Learner
montyLalor's Avatar
Dunno about the low fuel warning. It has done it with both tanks (duel fuel) well above half way. The petrol fuel guage works perfectly so I'd doubt any issue there.
This said though, I haven't even played or looked at the DTE functions yet. I imagine that the DTE updates with the fuel gauge (integrated system).
G6 ECOLPI
Old 14-08-2011, 02:03 PM   #6
STROPP
Mate does it have a ford alarm, if so three chimes is a flat battery alert for the alarm, needs a new battery pack available from battery world.
T3 TE 50 build33. FPVTICKFORDCLUBWA
STROPP is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 02:42 PM   #7
montyLalor
Padawan Learner
montyLalor's Avatar
STROPP,
No idea about the alarm. Is there some tell-tale sign I could look for for an alarm system?
G6 ECOLPI
Old 14-08-2011, 02:49 PM   #8
FGII-XR6
FGII-XR6's Avatar
STROPP,
a siren on the firewall near the brake booster
[SIGPIC][/SIGPIC]
Rides:
Old 16-08-2011, 11:52 PM   #9
Mechan1k
Mechan1k's Avatar
Only at startup???
One thing I'd check is the speedo ... is the speedo actually jumping up to about 20km/h with the handbrake on???? And doing it intermittently.
This is another cause of the chime you speak of as well.
The speedo sensor in the auto trans either needs cleaning or replacing if that is the case.
