Old 17-10-2009, 06:38 PM   #1
aufairmontghia
XR6
aufairmontghia's Avatar
Default Koni Yellows Won't Fit!!!!!!!
Hi Guys,
Picked up my Koni shocks for my S1 Fairmont GHIA the other day. Reds for the front & yellows for the back with IRS...
Got a problem!!!! The reds I fitted yesterday & are fine.... Drives nice on the soft setting!!! Am waiting for the yellows to go on till I adjust...
The yellows I tried to fit today & they didn't fit!!!!!!
When I say they didn't fit, the top of the shaft on the shock won't go through the top shock mount hole..... the shaft diameter on the shock seems to be bigger than the diameter of the shock mount?????
The part number for the rear shocks is 8241 1167SPORT.
Do I have the right Shocks??? Has this happened to anyone else??? :
aufairmontghia is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2009, 06:42 PM   #2
The Monty
Just slidin'
The Monty's Avatar
They are the right ones according to the Koni website.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 17-10-2009, 06:46 PM   #3
aufairmontghia
XR6
The shaft seems heaps bigger than the shagged monroe's....
I thought they were the right ones too!!!!
Old 17-10-2009, 06:48 PM   #4
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
get out the gas axe!
Chopped fairmont!
Seriously though, is the correct part number written on the shocks? Maybe they got packaged wrong.
Holden: If you cant beat them, buy them.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2009, 06:51 PM   #5
aufairmontghia
XR6
Ouch..... Poor Koni's!!!!!!
Old 18-10-2009, 02:08 AM   #6
Firebell AU3SR
Firebell AU3SR's Avatar
I don't know if this info will help??I remember reading about mik's problem.
http://www.fordforums.com.au/showthr...8&page=3&pp=25
Firebell AU3SR is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 08:26 AM   #7
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Pretty sure this is the post that you are referring to!
http://www.fordforums.com.au/showpos...0&postcount=65
"found my problem it was me , never did learn to read instructions , the missing link is the Koni yellows are longer in the shaft and thicker than the Ford/Monroe units, apart from drilling through the top plate and mount right through with 12 mm, you have to drill a 16 mm diameter hole up into the bottom of of the upper mount, NOT ALL THE WAY THROUGH, i found about 25 mm so that allows for the longer shaft to slide up further into the top mount and locate the spring properly for when the suspension is unloaded, from memory the alloy bit you have to drill into is about 40 mm in depth so there is still a bit of meat there, also you will need a spacer to go over the top thin bit of shaft, i found drilling the alloy bit a problem it wanted to spin in the rubber (yes its tired i`ll replace down the track), so a couple of 4 mm holles drilled to depth of about 4mm either side of the shaft hole and used my angle grinder key to stop it spinning while drilling the other end did the job."
Old 18-10-2009, 08:46 AM   #8
Dave_Obsession
Also, not completely related, but I did some mining on the original post I did regarding Koni's for my AU....and just noticed that the part numbers for AU's with IRS (aufairmontghia) as opposed to Live Axle (me) are different at the front?? I would have thought that all AU's would have the same front end part.......
AU'S WITH LIVE AXLE REAR:
http://www.fordforums.com.au/showpos...5&postcount=55
Fronts: K8241-1166SPORT
Rears: K8041-1067SP1
AU'S WITH IRS:
http://www.fordforums.com.au/showpos...6&postcount=70
(f) 8241-1166 SP1
(r) 8241-1167 Sport
Would anybody be able to say why the part numbers at the front would be different?
Old 18-10-2009, 08:59 AM   #9
The Monty
Just slidin'
The Monty's Avatar
Changing post too:
The part numbers you gave are the same, just missing a letter or two. The front are the same for all AU's only difference is series 2 on got a lug welded to slip the brake hose in.
Old 18-10-2009, 11:28 AM   #10
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
You must drill the hole out in the mount , it is only soft and does not take much to drill
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 01:21 PM   #11
JC
JC's Avatar
This must be why they say "Once you have Konis, you'll never go back!".
Ford Performance Club ACT
Old 18-10-2009, 01:42 PM   #12
mickyyyy
LOL becuz u carnt hahaha
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 07:05 PM   #13
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
ahahaha
Old 18-10-2009, 09:13 PM   #14
aufairmontghia
XR6
Quick question on the top shock mount.
I'll drill them out with a 12mm drill bit when I fit up the Koni's again!!!
Now I replaced the top shock mounts not too long ago & are in good condition.
If the centre section spins while drilling does that mean they have seperated from the housing & are stuffed???? Or are they still OK????
Old 18-10-2009, 10:49 PM   #15
GK
Walking with God
GK's Avatar
LOL! JC at his ironic best!
I hope you get it sorted soon.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-10-2009, 07:16 PM   #16
mik
mik's Avatar
i had the same problem with the alloy bit rotating, i still havent changed the top mount and its hanging in there ok, but i suspect it may allow a little more movement than would otherwise be with new mounts, i left my back seats down with the covers folded forward on the rear shocker towers and checked them out while my brother was driving , they don`t appear (on mine anyway) to be going to push through the rubber even while going over our fairly bumpy streets, and its handling very nice almost to the point i`ve had second thoughts about changeing sway bars, i had an evil thought when i was at repco regarding the expensive top irs mount on our Henry`s i was going to change mine at that time on the weekend , they did`nt have one anyway, but they did show me a commodore one , it looked about 1 tenth the size of our Ford one and cheap to boot, it occured to me perhaps a commy one may be adapted to our Au`s, i will look at this a little bit down the track, please don`t banish me for thinking of commiting AU dultery with holden parts :
Old 20-10-2009, 07:18 AM   #17
aufairmontghia
XR6
MMM Sounds very interesting there!!!
The other thing I sussed out was the rear top shock mounts from an AU with live axle..... They look very similar BUT who knows!!!!!
Old 20-10-2009, 09:37 AM   #18
Dave_Obsession
Have you thought about getting a professional to install them? that way if any problems, it's on their heads (and cost) to fix?!
Old 20-10-2009, 05:59 PM   #19
eXi7w0unD
eXi7w0unD's Avatar
hmm i got koni yellow adjustables (sport) just damper adjustable not height. i have them all round they fit... of corse i got fulcrum to install it all.
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
