27-02-2006, 03:00 PM | #1 | ||
Hi Guys. I just saw mention of installing a k&N filter in the new focus and a link to the product here:
http://www.knfilters.com/search/prod...x?Prod=33-2886 My question is, how much difference does it mate, would it be noticeable and worthwhile doing? Also, how much do they charge for them? Cheers, Owen. |
27-02-2006, 06:21 PM | #2 | ||
I was also considering one of these, I rang my local repco and they said they can't get them in. I guess I'll try Autobahn when I'm at the coast next.
Current car: 2022 Escape st-line - Previous Fords: 2006 Focus, 2009 FG XR6T, 2009 Focus, 2012 Focus, 2016 Territory |
27-02-2006, 09:44 PM | #3 | ||
WRC Fanatic
In terms of quantifiable performance gains, you will get very little, if any (maybe1 -2 hp tops), which you certainly will not feel. If you are planning other mods down the track, it is a worthy upgrade as it will help your car breathe better (especially combined with a performance exhaust system). Probably around $100 in Australia, but you can often do a lot better by purchasing online.
Panther Black XR5T Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph |
27-02-2006, 09:57 PM | #4 | ||
Zoom Zoom
I honestly don't really notice much if any difference, again it's barely noticeable even on a dyno. Your engine is tuned to best performance using the factory filter and unless you drop on an exhaust, chip and filter together, gains are negligible. So as a stand alone mod, not really worth it but with at least an exhaust, probably worth a look. At the end of the day, more air in means more air out and unless you increase the flow of the exhaust, extra intake can only go so far.
2012 Mazda3 MPS
28-02-2006, 08:57 AM | #5 | ||
Thanks for the input guys Much appreciated.
28-02-2006, 10:18 AM | #6 | ||
The greatest advantage is that they are re-usable which should equal less servicing dollars over time
28-02-2006, 11:44 AM | #7 | |||
Whipple Induced
There maybe a slight improvement in fuel economy as well, but if it's enough to offset the cost is another matter.
28-02-2006, 07:29 PM | #8 | ||
I've just had a 2 1/2 inch exhaust done on my new focus and i was looking at one of these next, anyone know of a good site to get them from?
28-02-2006, 08:03 PM | #9 | ||
Zoom Zoom
Under $100 is your guide, just get htem from any reputable exhaust or aftermarket centre.
2012 Mazda3 MPS
28-02-2006, 11:01 PM | #10 | |||
Cheers, Owen. |
01-03-2006, 03:26 PM | #11 | |||
01-03-2006, 03:52 PM | #12 | ||
Old enough to know better
Worth looking at BMC filters as well. Was always my preference. European not US
01-03-2006, 04:05 PM | #13 | |||
01-03-2006, 04:18 PM | #14 | |||
01-03-2006, 07:41 PM | #15 | |||
I'm also interested.
01-03-2006, 10:59 PM | #16 | ||
I reckon the BMC performs better, but have no dyno results to show. The McLaren and Ferrari Formula 1 teams use BMC, so they do know something about Filter technology. You'll pay more for a BMC though, for minimal if any gain over the K&N
Autospeed reckon they tested heaps of panel filters, and argue that unless you change the whole airbox, you'll get minimal results with an aftermarket panel filter
01-03-2006, 11:04 PM | #17 | ||
Zoom Zoom
The Focus builders handbook also backs up this point about minimal gains on its own, returning the following
"It should be evident by the results that installing a simple drop-in filter is worth very little in terms of added horsepower." Gains recorded were 2-3 horsepower. Negligible and less than you'd "feel" by using a higher grade of fuel or a fuel octane booster I'd dare say. The only main benefit, as mentioned above in an otherwise stock car, is the cost of replacement is nil once you have a K&N, however remembering that it has to be re-oiled, it still works out cheaper in the long run than constant paper filter replacements. Just not really worth it stock.
2012 Mazda3 MPS
02-03-2006, 11:36 AM | #18 | ||
hm.... what if i were to ИИИИ off the entire airbox etc and run a pod filter right down the front just in front and to the right of the radiator?
12-03-2006, 05:34 PM | #19 | ||
your talking about a long ram pod, lotsa tourque, lotsa nice cold air. The thing with the focus here in australia is the under hood temp, in summer it gets f'ing hot under there. A short ram pod just sucks very hot air into the engine which is not what you want. Ive just installed a long ram on my car this summer (had to take the short one off last summer cos i was having serious power problems due to the hot air) and while theres a slight extra power gain, its not really that noticeable, except maybe when you boot it from a red light.
The only thing you need to remember with air intake is the colder the air the better. Some people get the same power gain from a decent high flow panel filter and cold air ducting from the front of the car (for a normal aspirated car anyways, turbo is a whole different bag of elephants). |
12-03-2006, 06:09 PM | #20 | ||
Focus on my Focus
Hang on... does this whole cold air thing mean that you'd get more power in winter?
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
13-03-2006, 03:39 PM | #21 | ||
nope just more consistant power. The extra power you get from a pod on a non-turbo/supercharged car is pretty ИИИИ weak, still makes the engine sound great from the induction noise.
