hi
got given a 42 inch lg plasma that doest work and when you turn it on at the power theres just a white flashing led and it doesnt turn on cant even push power button. but when you unplug the y-sus board and turn it on at power again it still doesnt turn on but power button can be pushed and the led is white when off standby and red licht comes when on standby. anyone know what it could be, never worked on plasmas before and in that hobby would it be the screen, ysus board or power supply whats the chance of the plasma panel still being ok also have a nec lcd tv and it turns on but picture goes out and theres still sound but no picture anyone know what itd be Last edited by car10002; 30-11-2012 at 10:12 AM. |
i have fixed quite a few of the lcd/plasma tv's and lcd monitors myself.
my father is a retired radio/television telstra technician, so i learnt a lot from him when i was young. first up, this is only my advise, i will not be held responsible if you damage/hurt yourself, the tv/s, circuit boards etc. disconnect the power before you touch anything, and remember that the capacitors hold a charge until they are shorted, so try not to touch the pcb's too much, you may get an electric shock. if you are unsure with soldering etc, and post up a pic of the board, i could point out which ones should be replaced. then you could identify them and buy new ones, then have a technician replace them for you. you will need a small pointed soldering iron (around 25w) somefine (under 1mm solder) some solder wick to remove the old components, and good eyes to read the details off the side of the capacitors, lol but, with both tv's it would/could most likely be the lcd power board capacitors? if you know what you're doing it is easy enough to repair them (lcd/plasma tv's/monitors)cheaply. check out the lcd/plasma power supply board capacitors, there are usually 4 or 5 of them. the tops of them will rise and make an convex shape, sometimes leaking and giving a bad smell too. replace them with higher voltage ones if possible, eg; go from 25v up to 35v capacitors, or 10v up to 16v or even 25v. if you cant find one in the same range eg; 3300uF it shouldnt give you any problems using say a 4700uF. jaycar keep a lot of different ones in stock, and are cheap enough to try. otherwise most of the lcd power boards are available on ebay (do a worldwide search)etc, either new or reconditioned and aren't to expensive, some are around $60 for the board then you can just plug it in. if you have trouble finding the capacitors post up a pic and i'll point them out to you. what state/area are you from? cheers, craig
Money Talks, but all i ever hear is it saying Goodbye!! |
Bolt Nerd
![]() Join Date: Jan 2005
Try this forum. http://www.tv-forums.com/forum/TV_Eq...pair_Forum_F3/ mate instead of us grease monkeys
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
just bear in mind if you have never had a plasma, they generate a lot of heat and use a lot of power that's why they are not that popular now.
these things are great in winter but a nightmare in summer
[SIGPIC][/SIGPIC]
the Plasma tv's have pretty much the same power supply circuits as the older style LCD tv's.
so they generate about the same heat, a lot of it comes from the backlighting's fluro tubes. the newer LCD tv's use a LED backlighting setup, so radiant heat is a lot less from them. here are some of the faulty Capacitors , and a couple of Diodes that i have recently replaced in a Plasma, and a LCD TV (a couple of weeks ago) to fix the no picture, but sound works, fault. not all faulty Capactiors will bulge at the top and be obvious though, see the 3 blue ones on the right you can just notice a buldge, and easily see the big black one bulging on the right, for the cost, it is worth replacing them all. the new ones (spares) are pictured above the bottom row. ![]()
here are some pics of the internals of the 42" Plasma tv i fixed.
the display power board is the top middle one below. ![]() closer pic, ![]() and closer again. ![]() the 4x black capacitors at the top were replaced, and the 3x blue ones going down too. ![]() here is a pic of the old blue ones, and the new black one that they were replaced with. the faulty ones were 10 volt, 3300 uF ( the uF symbol is Microfarad's, the measurement), the replacement ones are 16 volt, 4700 uF using a higher voltage capacitor will hopefully let them last longer, i used the higher, 4700uF , caps as no one locally had the 3300's in stock. the small difference (3300-4700) doesnt really effect the circuits etc ![]()
car10002,
did you have any luck fixing your Plasma TV?
