Has V8 envy
hey guys. help needed again. brother is getting his AU pursuit ute (2001) capa flashed/custom tuned. where does he find his ECU number so that the right flash box is ordered?
cheers.
2005 BA F6 Typhoon 360rwkw GTX35/82r + 82lb injectors Nizpro 4" exhaust Plazmaman 1000hp IC/piping/BOV/plenum Process West surge tank Crow springs TEIN super streets 6/4 brembos TUNED BY BLUEPOWER RACING
in passenger side kick panel closest to the door, just unscrew the panel under the door and fold the carpet up, you will see the ecu. get a mirror or try and put your head under it to see the sticker with the number on it, do not try and peel it off, it will break apart, i done this and had to get the number the hard way, which meant hacking to death the security screw/rivet holding the ecu case, and the sticker is on the back of the plug on top.
Has V8 envy
Thanks for that buddy.
#4 | |||
Back to Le Frenchy
I'd tell him to wait.
http://www.fordforums.com.au/showthread.php?t=11248233
#5 | |||
