21-05-2019, 12:22 AM | #1 | ||
I want best mile's I could get
227 ks just bit over the half a tank what I doing wrong? New exhaust New o2 sensor New catalytic converter New injectors New fuel pressure regulator New fuel pump New fuel filter Did reset the car just sucking fuel.. Any more idea's as losing battle with the car just Goin to trash it can't afford much to keeping it running.. My kid is in Victoria while I am in SA so do need my car to visit her...
Ford Au Falcon 2001 Sr XD FaceBook Fans Club Only for FORDS Ford Club On FaceBook! |
21-05-2019, 01:50 AM | #2 | ||
How much is half a tank? Have you actually measured how many litres you used for that half a tank? When you work out how many litres you used for the km then we can tell you if it's good or crappy!
Maybe the gauge is out? |
21-05-2019, 01:52 AM | #3 | ||
The gauge is 100% correct lol I know that from experience running out of fuel when it was worse than it is now. (200ks a tank) .
My old au1 as my avatar did 270ks to half the tank
21-05-2019, 02:01 AM | #4 | ||
I might drive up the half.. 30 ks more then it might be 250ks to half..
I'm so confused I'm schizophrenia.. But put an old style Ford or Holden carbie in front of me I will make it run like new.. My old Ford falcon xe 250 crosflow on gas gets 506 ks city driving 600 petrol city which was great.. Just can't compute with the car tune
21-05-2019, 08:08 AM | #5 | ||
Next upgraded Mk1 Leopard
My old stock AU II 6 cyl would do at best 400 city ( less on LPG)
Uk
21-05-2019, 09:49 AM | #8 | ||
New catalytic converter mate basically new everything do with flow and fuel..
Moving fast not slow smoothly like before au1 should be the same as au2
21-05-2019, 09:50 AM | #9 | |||||
That's what my lpg does.. But talking about petrol.. Which I aren't happy with.
21-05-2019, 03:53 PM | #10 | ||
Au Falcon = Mr Reliable
Check the inlet manifold bolts are tight & the gasket is in good condition & not cracked, good luck!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
21-05-2019, 04:41 PM | #12 | ||
I done 260ks it's on half a tank.. Petrol.
Lpg is not what I'm worried with that does 500ks but lpg slowly fading away and petrol is more strong pulling loads..
21-05-2019, 04:45 PM | #13 | ||
I did calculations getting 13.3/100ks so I should fill up then drive it like adult
And see how far to a tank
21-05-2019, 08:52 PM | #14 | ||
Drive'n Cruise'n Live'n
My AU2 SR, I am averaging around 10L/100 with a 50/50 mix of around town and 80kmh semi rural trips. Using BP95 now to help clean up the dirty fuel from the servo I used to frequent. Cheers.
21-05-2019, 09:17 PM | #15 | ||
99.9% me city driving.. Which sucks most of the time..
21-05-2019, 09:53 PM | #16 | ||
13L/100km isn’t too bad for an AU around town, might get a bit better driving like a granny!!
2 users like this post: |
21-05-2019, 10:08 PM | #17 | ||
I going to start this Thursday.. Give it a bath while it does it job
22-05-2019, 12:23 AM | #18 | ||
When first start up it will show 2.20 and reading rich.. But once warm this what shows
24-05-2019, 01:50 PM | #20 | ||
what about the THROTTLE POSITION SWITCH ?
UK
25-05-2019, 10:17 PM | #21 | ||
Got back from repair and other reset the au2 Sr..
Clean the o2 sensor again and boom now she's done 620 ks city driving.. (driving normal..) 598ks driving like a noob.. Well just needs a love.. Only problem is starts longer now
25-05-2019, 10:38 PM | #22 | ||
600km is a pipe dream, they do 450km at best around town.
25-05-2019, 10:40 PM | #23 | ||
That's why I stop whining about ks in the city.. Lmfao
Just need to talk about it
