Old 29-05-2007, 05:13 PM   #1
Soogle182
Talking Stop light switch or cruise control brake switch... which one to change :)
My cruise control is not disengaging when I push my brake pedal, and I have been told to change the brake light switch. Only problem is in my trusty Gregorys manual, there is a switch off the master cylinder which is called the Cruise Control Brake Switch... is this the one I need to change or the one of the brake arm??
Any help would be great cheers fellas
Soogle182 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 05:28 PM   #2
efgiar
rofl copter
efgiar's Avatar
the one on the master cyl is an emergency one, check ur stop lights are working, if they arnt, check ur fuse and if thats ok check your stop light switch
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 05:35 PM   #3
daz82
In the family since 1996
daz82's Avatar
If it is an EF or EL then the brake switch does both brake light and cruise disengage functions.
if your brake lights then fail there is a fluid pressurre switch to back it up and disengage the cruise.
if it is pre EF then you have two seperate switches for brake and cruise functions.
daz82 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2007, 10:27 AM   #4
Soogle182
cheers fellas
