Old 07-05-2024, 04:16 PM   #1
Luka
Default Size of vacuum hose for fuel regulator to intake manifold?
Just replaced intake manifold gaskets and noticed this vacuum line is not in great condition and needs replacing. Does anyone know what size it is? thanks
Luka is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2024, 05:07 PM   #2
Default Re: Size of vacuum hose for fuel regulator to intake manifold?
You don't say (and you should always state: model, year, engine and trans configuration so we are not left playing detective) but I guess we have to presume it's your 97 EL again. It might also be more appropriate to post in the relevant section here https://fordforums.com.au/forumdisplay.php?f=29 or even https://fordforums.com.au/forumdispl...er=desc&page=2 rather than in the Pub. In any event, I suggest just measure it with verniers and get the closest fitting size here: https://www.supercheapauto.com.au/se...ose&lang=en_AU or take the old one to Supercheap or wherever and match it.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 08-05-2024, 12:37 AM   #3
Itsme
Experienced Member
Itsme's Avatar
Take it off and go to any auto shop, they will give you the correct size and length required.
Old 08-05-2024, 11:33 PM   #4
oldel
Always bet on 3mm.
If it ends up being 4 or 5 mm then there's a chance the 3mm could still be forced on with hot water or heat gun. Vice versa no good and will leak
Seriously though, that looks old, looks like 5 mm.
oldel is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2024, 11:52 PM   #5
66 coupe
around the place
66 coupe's Avatar
get some 4mm i.d silicon hose. re-route it from the reg around to that barb furtherest from it so you get a decent bend diameter on the hose. the hose that was on that furtherest barb, move it to the one closest to the reg.
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
