what temperature, is best to set my thermo switch, for the fans to kick in?
i just fitted them the other day not many problems. just little, easy to fix ones hope they are as good as everyone has said they are Damon |
PM me if you want
what ever makes you comfortable, before reaching half would be a good idea.
/\/\etaL and V8s -Awesome
Got mine set just under half, when they come on, it takes the temp back to quarter pretty much straight away. Hate my car running half or more!
Cheers ViGiLaNtE351 |
Couple of degrees higher than the thermostat.
62.5 degrees
The Old: 1993 ED Fairmont 1994 ED Futura Classic Manual, 2004 BA MkII XR6 Turbo 2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing) 2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit) The New: 2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade) Other Road Toys Silver Surfer 2014 S-Works Roubaix SL4 road bike with Roval Rapide CLX 40 wheelset The Adventurer! 2023 TREK Domane SL 7 AXS Gen 4 |
PM me if you want
thermostats in the e-series are 91 to 95 pending brand from what I have seen.
Barnsey, where'd you get that figure from?? Thats only just off cold!..LOL
Most cars run between 75-95C at extremes! Cheers ViGiLaNtE351 |
just made it up
SnortPerformance.com
Standard thermostat temp from ford is 91deg celsius. The Tridant ones from coventry are 92deg C and the ones I buy from Repco are 91deg C. I have an 82deg C thermostat in mine and a thermo switch from a Subaru of some description that comes on at 95deg C and off at 90 deg C.
Sounds a bit miss matched, I know, but it works perfectly for me. Fans come on at the top of the 'R' and off at the bottom of the 'R' then the temp normally continues to drop to middle of the 'O' on the guage after the fans turn off. Perfect. Problem is, the only way I found all this out was trial and error. I wanted to have a thermo switch that screwed into that unused hole in the thermostat housing so it had to be short and have a thread of M16x1.5 to fit and then I had to also find a temp that would work. Anyway thats what worked for me, hope it helps. |
thanx heaps
#11 | |||
EBII XR6
DEVLXR
#12 | ||
how do u change when the fans come on???
On the Davies Craig switch its a dial type setup, anti-clockwise to come on sooner, clockwise to come on later, in the middle is roughly when your gauge reads about half.
Otherwise like BI6TIM said, buy a fan switch, (I was going to put it in the same place also.), but found the D.C switch works well, and is adjustable. Cheers ViGiLaNtE351
Nothing Sounds Better Than A V8 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BA XR8 MKII EB Falcon ThermoFan Conversion http://www.fordforums.com.au/showthr...t=vigilante000 BA Falcon ICC Speaker Wiring http://www.fordforums.com.au/showthread.php?t=11342785 BA Wiper Motor in XE http://www.fordforums.com.au/showthr...=1#post5393955 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
#14 | ||
I think I have my fans set to come on at 92 and off at 87, or something like that (Haltech), which is just on the 'N' in Normal and off halfway between the 'N' and the bar to the left on my gauge, so it seems that either my temp sender, BI6TIMs sender, or either of our gauges is a bit out....
#15 | ||
Hence the aftermarket gauges coming scro.
