03-02-2007, 06:17 PM | #241 | |||
fit 'n' turn
Awhile ago one friday night after work (3:30pm) i was just about to head off to wangaratta to go on a first date with my now fiance. Pulling into the driveway at home i hear the bearing in the alternator has ***** itself. I go to the auto elec and grab a newie, goes in no worries (5:30pm) only the lock bolt to put in, for some stupid reason i decide to start the car and see if the noise is gone. So i start the car, noise is gone, jobs done? NO, with the car still running i reach over to put the bolt in, the bolt falls thru my fingers down between the harmonic ballancer and shatters the bottom half of the timing case!! FU%K!!!!!!
To make matters worse my harmonic puller stripped the thread had to buy a new one and the last person (probably me) to take the fan off had rounded the head on one of the four fan bolts, and i had to take the water pump off with the fan still attached (not easy) Finally got the car back together (4:30am) after 10 hours and the test drive was straight to wangaratta the next morning. THE AWESOME POWER OF THE PUSSY! Cheers
03-02-2007, 06:52 PM | #242 | ||
xygtho
well this is what ive done.The first time i put new spark plugs in the xy, easy u'd think. when i put the leads back on i put then in order 123456 instead of the firing order. tryed to start it and all i got was white puffs out of the carby and some strange noises. so here's me freaking out thinking ive stuffed my pride and joy . talk about embarrasment seeing as i boke up my dad's card game with his 5 mates telling him ive rooted it then he fixed it in 2 seconds and i never lived it down. didn't damage anything but felt like a complete noob.
03-02-2007, 10:42 PM | #243 | ||
best ive seen has been mate droping his car off a hoist 8ft in the air
(ps he is a mechanic so should know better than to do what he did in a car yard) lmfao |
03-02-2007, 11:04 PM | #244 | ||
Some really funny reading here. My turn - this happened recently:
Two months ago my partners mother was complaining about the rear end bottoming out when she went over bumps. Me, being the caring buttsuck that I am, said "Go buy shocks, I'll install 'em for you". A week later, shocks arrive, no problems, jack the car up (with a hydraulic), pull a shock out, to the vice, push-pull-push-pull, find it's well and truly gone, etc., etc.... I look over to the far wall and see a set of what looks like some heavier springs. Methinks, "the car's already up... whack'em in, see if they fit." Pull out the old spring, measure them - 1 1/2 inches shorter, but heavier, same diameter, no problem. I go to put one in - it's too short to sit in the cup, so I put my head over the rear wheel so I can make sure the spring seats properly... as I lower the jack.. I can tell you, the rear end of an EA is even harder to lift by hand when your heads caught between the rear wheel and the arch! Screaming like a ******, I was stuck under the car for a good full minute, holding it up so my neck wasn't crushed, until my partner reached me and managed to jack the car up. What made matters worse was that I had to explain to her how the use the jack with my head still under it, panicking to the sh!thouse!
Humpy Humpy!! 78 Cortina project - 4.1 5 speed, 350 Holley, Extractors: to do: fit gearbox, air conditioning, roadworthy & rego 83 XE Falcon in stock rust trim, pre-compliance LPG, PB 390km/62l B.Arts(Latrobe), PGradDip CompSci(Latrobe), Cert IV Basic Electronics(BRIT), B.Beer(Latrobe), M.Bullsh!t(Ford Forums) |
09-02-2007, 01:00 AM | #245 | ||
[QUOOnly two weeks ago, I jumped in the car, put it in reverse, and away I went. Only to hear a big bang, and did not realise I didn't open the garage door! Opps.
My missus went off as I did this same thing only 4 years ago...... __________________ BF Bionic F6 Typhoon..............manual, leather, sound, 19's, momo steering wheel and 550nm of Ford 4 litre muscle TE] HA HA, Charter boat????? what charter boat? |
09-02-2007, 02:35 AM | #246 | ||
[QUOTE=AU Man]I too have done a few of the things mentioned above . I can add the following.
I just finished changing the rear brake pads and tightening the wheels then i placed the mag wheel lock nut on the roof of the car so I would remember to put it in the glove box when I got in the car. Sure enough I forgot and went for a drive to bed in the brake pads with the wheel lock nut on the roof. I spent many hours with a punch and hammer getting those lock nuts off!QUOTE] Cut the end off a spark plug and belt it on with a mallet :evil3: |
09-02-2007, 08:15 AM | #247 | ||
Threw an power extension lead over the top of a car (work in progress). When I walked around the other side I realised it had landed in a 44-gallon drum of water (from the washing machine in the shed). I stuck my hand in the drum of water and retrieved the end of the lead .. walked back to where it was plugged in an realised it was still turned on?! Don't know why I didn't get a shock?
09-02-2007, 09:53 AM | #248 | ||
Pet_ED
Changed an auto transmission on the ED and didnt put the torque convertor in the tranny far enough.
When i tried to turn over the engine it was jammed and bent the torque convertor and the tranny pump. Had to pull the tranny out and replace all the bent stuff. $$ At least the flywheel wasnt bent.
93 ED Classic JVC KD LH2000 Head Unit King Super Lows 2.5" Exhaust Blue Dash LED Conversion EL Thermo Fans 15" Mags Bridgies Grid II 225's |
09-02-2007, 11:08 AM | #249 | ||
Budget Racer
A mate was working on his car in his driveway. Things were not going as planned so he vented his anger on his socket extention. Throwing it as hard as he could down the driveway.
Imagine his surprise when it hit the ground only once before bouncing across the road, over the front fence of his neighbour and smashed through the front window! But not just any neighbour, it was the neighbour he did not get on with. Who had complained to him since he moved in about cars/noise etc, who had rung the police before and generally was just looking for another reason to complain. My mate knew his neighbour was on holidays, so quickly made his way across the road to try and hide the evidence. He was just in time to meet another neighbour at the gate. That neighbour asked, "did you hear that?" and said he had a key to get in! Thinking quickly, my mate told him to go around the back and he would go in through the broken window. My mate climbs in through the broken window and cuts himself quite badly. Finds himself in the main bedroom and starts looking for his socket extention. Can't see it until he looks under the bed and quickly sticks it in his pocket just as the neighbour arrives from the back door. There is blood is all over the carpet and the bed. The neighbour arrives home from holidays and hears the story of my mates bravery protecting his home form a breakin. He arrives on my mates door step with a slab, apologising that he had miss judged him. They have remained firm friends since. :
12.1@112Mph 285rwkw on n2o Cleveland Power |
09-02-2007, 11:29 AM | #250 | ||
Next upgraded Mk1 Leopard
Last century I changed the oil in my 2.6 lit Magna. Drained the old, changed the filter, toped up with new and headed off to Parramatta. After stopping at a set of lights on a slight hill the car was hardly moving. Limped home, checked the oil and it was way over the full mark on the dip stick.
So have you figured out what I had done? Yes I had drained the auto trans fluid instead. Ended up OK, the car was still covered by warranty and the nice lads at the dealer replaced the auto trans for nicks. I was one happy and Lucky camper. Uncle Ken :togo:
09-02-2007, 12:56 PM | #251 | ||
DALLY 41
replacing fuel pump... decided the one way valve would work better backards...
later found it running shitfully.. took it to ford had put a CPI pump into my EF ding dong
own a falcon? live in perth? www.perthfalcons.com |
09-02-2007, 04:01 PM | #252 | ||
Long Story,
Rebuilding my clevo, a mate was replacing the thrust plate and timing gear set. Put the larger gear in backwards (hmm) when the motor was turned buy hand it ground the thrust plate into sand. I spent 2 hours getting it all out with a vacum.... Going to a wreckers to get another one.... I dropped one of the wreckers (big dude, looked like a viking) sockets down the front oil gallery of a clevo that was about to be sold for scrap. It was a good sidchrome one too. ive never been back there. |
14-02-2007, 09:37 PM | #253 | ||
Done most of these at some time or another, except setting car/person on fire
My best story is we were checking the oil, water etc on a friends Pajero just before he drove back to Brisbane and left a Makita rechargeable torch under the bonnet. Friend drove back to Brisbane which is about 2000kms from my place. About a week later I realised I was missing the torch and thought when I last used it, called friend and asked if he put it away somewhere different or something, NO he says, I say just go check under your bonnet, there it was, fallen down between the radiator and something else. He had taken his car into Mitsubishi down there after his trip for a service as well and they never found it Got it back a few weeks later via a 3rd friend who was coming to visit Anyone got a tool that has travelled further?? And returned safely. |
14-02-2007, 09:57 PM | #254 | ||
BrwnBstd
Only a set of vise grips that stayed on a hand brake cable for a month or two!!
14-02-2007, 10:01 PM | #255 | ||
BrwnBstd
Speaking of which..
On the weekend, I reversed the ba onto some ramps to fix said handbrake, usually I do this on grass, this time as it was hot, so I did it in the carport (smooth grano). Half way up, I had to give it some more gas. BOTH ramps shot forward, the car stayed still, bang.. I am glad I have only lowered the front and not the rear as the damage was minimal, the car ramps are cactus. Do not do this. |
15-02-2007, 12:44 AM | #256 | ||
The Guy You Love To Hate
Ok i am guilty of one last weekend.
i was helping a friend with his car last weekend, and had the car up on a hoist. I was using the hammer and decided to hang it off the sway bar since i didnt have a tool belt or anything. Anyway, i forgot about it and my friend started lowering the hoist and the car stopped coming down when it nearly reached the bottom before going BANG and crashing down. Turns out the hammer had been supporting the weight off the car by pushing in the sump and balancing off the crankshaft and the floor!!! Not happy friend afterwards... |
15-02-2007, 01:24 AM | #257 | ||
Gunna girlie-man
i started cutting some holes in my parcel shelf for some speakers in the ea. using an angle grinder, and remembering half way into it i had the lpg gas tank in the boot. woopsie :(:(
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
02-05-2007, 10:15 PM | #258 | ||
Last Weekend, Had A Mate Over To Service Car. Anyways Serviced His Car Then He Wanted To Help Me Strip Mine In The Shed (project Xc) I Asked Him If He Wanted To Remove The Passenger Front Door, He Was Like... Yep Cool. Stood Behind Him Passing The Sockets For The Bolt And He Was Saying "nope, Too Small, Nope Too Small" For Bout 10 Sockets. So I Was Like" Give Me Alook Mate"..... He Was Using The Half Inch Side Of Each Socket (28 Years Old). I Was Stunned But Good On Him For Having A Go
03-05-2007, 12:56 AM | #259 | ||
[QUOTE=Laminge]Dropping the keys into the petrol tank of my vh valiant, and spending 4 hours hooking them out, and 24 hours detoxing from the petrol fumes
What were you doing to drop your keys into the petrol tank??? :
jaydee351 4DV8 |
03-05-2007, 01:10 AM | #260 | ||
This is funny
Just got my BA GT parked it in the shed and went away to work for 2 weeks. Fly back home go to start the GT. Nothing happens dash lights come on but motor will not turn over. Ok flat battery. Go and buy a starter pack get home hook it all up and it still wont start. I mess around for 2 hours getting very ****ed off. I forgot about the starter button.
Drive it like you stole it. FPVTICKFORDCLUBWA New FG XR6T ZF |
03-05-2007, 01:27 AM | #261 | |||
HSV - I just ate one!
03-05-2007, 04:40 AM | #262 | ||
Powered by Ford
My mate and i went halves in an xy ( project gt mock ) i had some 2" lowering blocks for it so i jacked the car up and placed the stands under the DIFF HOUSING, my mate who was under the car had just undone 1 nut from a u bolt when his old man walks in and said WTF are you doing, you trying to kill yourself. We both looked at each other not knowing what he was talking about. He says your not supporting the car, as soon as the u bolts undo, the car will drop on you. That was 13 years ago, still freaks me out thinking what would of happened if his old man didnt walk in the garage.
I was sitting on the bench seat that i just pulled out from it reading the trading post looking for a 351 clevo. Last edited by BZINGA; 03-05-2007 at 04:46 AM. |
03-05-2007, 08:54 AM | #263 | |||
03-05-2007, 09:22 AM | #264 | ||||
Cuban... nothing like it
[QUOTE=jaydee]
The filler was behind the number plate. The key on the cap never locked so I sat down one day and tried to work out why the cap would not lock into place, I placed the keys in a position to keep the plate down, obviously in a position to launch the keys into the tank when the plate snapped back up.... :
03-05-2007, 09:52 PM | #265 | ||
eskyman
i know how you feel with the cap not locking on. exact same think happend with one of my escorts
who says kents cant be quick |
03-05-2007, 10:38 PM | #266 | |||
one of my worse mistakes was to fill up a diesel 4wd with unleaded fuel. it was a lapse of concentration on a pre-delivery inspection. there was an 'unleaded fuel only' sticker on the inside of the the fuel door. |
03-05-2007, 11:09 PM | #267 | ||
Upside down jiggering the radio in the wife's Colt on my almost plat driveway. Handbrake stuck in back .... let it off to ease the pain... the colt rolls back, door ajar. The open door hits the Falcon bumper
04-05-2007, 12:19 AM | #268 | ||
Had my TE cortina service and the oil light was on the dash so I put another 4lt oil in it. Well it was blowing more smoke than puffing billy
04-05-2007, 01:14 AM | #269 | ||
ORSM Ford Cruisers
the garage should have been bigger. way bigger. we can just fit 2 cars in there and a work bench. thats it. you have to walk sideways through the cars and the bench.
oh and i forgot to put the positive wires back on the battrey and wondering why it wouldnt start. lol
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
04-05-2007, 01:42 AM | #270 | ||
Crash test pilot
i had a ford festiva and it had a very very slight leak from the rocker cover gasket. anyhow i decided to tighten the rocker cover bolts and i snapped the head of a bolt off the bolt and half of the bolt stayed in the rocker cover.
anyhow thinking that it was just a rocker cover, i drove the car to work and when i stopped, it was raining oil lol, i had to park it on the side with plastic bags under it untill my boss got the bolt out for me. 2nd story was not checking how oiled my clutch cable was on my motorbike and it snapped when i was riding. i had to ride 15 minutes home with no clutch in bad traffic (each time i stop the bike, it turns off, and each time i wana turn it on, i have to push it and crank it lol) not a great experience...
: Newest Addition Holden Barina 2004 6L per 100k : 66kw : Old Collection.. Falcon BA Toyota Celica Kawasaki zxr Ford Festiva Nissan 180sx Daihatsu Feroza |
