04-01-2015, 12:11 PM | #121 | ||
Au Falcon = Mr Reliable
Well said Iggle Piggle! Can we agree, if Ford had spent extra dosh on better oem tires for the last XR8, the track test result's would be in the Falcon XR8's favour?
Wheel's & Motor et al', track test please between these two adversaries at Phillip Island same tires & tire professional's looking after those duties not you ok.... cheer's, Maka
04-01-2015, 02:30 PM | #122 | ||
as in chopped
I think we all agree that we won't accept the track results until the XR8 does the fastest lap. Then we can all say what a fair and great review it was.
-> Reading this signature was pointless <- |
19 users like this post: | 40RDT, 4stanger, 701let, barnz_xr8, BENT_8, DW260, Falcon SXR8, graphicgoose, Homer, Iggle Piggle, jasen, johnydep, LooLoo18, mcnews, rev, sexyxe, Struggo, tempted, Thunderchild |
04-01-2015, 03:52 PM | #123 | ||
I didn't realise the gts ran the same suspension as the redline...
Previous Rides Bionic BA MKII XR6T 245kW I6 Turbo, 6spd Manual Grey (yuk what was I thinking) AH Astra CDX Coupe 93kW NA I4, 5spd Manual Sensation FG XR8 290kW NA V8, 6spd Automatic Current Rides Octane GTF SC V8, 6spd Manual, Manta 3" X pipes and hotdogs Starlight Lotus Evora S 258kW SC V6, 6spd Manual |
04-01-2015, 04:13 PM | #124 | ||
04-01-2015, 04:26 PM | #125 | ||
04-01-2015, 04:47 PM | #126 | ||
Car tragic
Lot of hot air expended on this.
Some here clearly won't believe until a Ford "wins". May need to toughen up a bit. Some here clearly believe the Holdens are better cars. Depends on what you are after. IMO a car "as delivered" without modification bar no-cost adjustment (eg fuel loads, tyre pressures) is how they should be tested if determining which one is the best at a particular test when "stock". When a test with a professional non-manufacturer aligned curcuit driver with good condition hot OEM tyres at the correct pressures is run we will know the best track car as sold off the showroom floor. When a test with an experienced quarter miler with good condition OEM tyres at correct pressures with ambient temperature under 30 degrees then we will know the best in a straight line. Rest is conjecture. Before cries of "bias", I have a manual XR8 on order, not necessarily because it is the "better car" (in SSV vs XR8) but because it is more exciting (I like old-school muscle cars but need someting more practical), IMO looks and sounds better "stock" and it is the last (and likely the best) of an iconic Australian-made line. Wont criticise anyone getting a SS/SSV, but I suspect I will be less likely to mistake mine for someone else's in the carpark and as cars advance the more individual car will be the most revered. |
04-01-2015, 06:22 PM | #127 | ||
"Final 8"
I didn't know Ford, or Holden for that matter, manufactured tyres?
FG-X XR8 - "FINAL 8" Manual - Smoke PXIII XLT - Meteor Grey 3.2 6spd Auto
04-01-2015, 06:50 PM | #128 | |||
Car tragic
I will replace the original tyres with the best available for my needs when the time comes, who wouldn't? When changing tyres for performance, this is no less a mod than adding boost or modding intake, exhaust or ECU....ceases to be "stock"/"as supplied". Be great if the extra $1K proposed RRP was for better spec rubber but expect that is a forlorn hope..... |
04-01-2015, 06:53 PM | #129 | ||
For me (and the reason I chose a GT) was because it didnt have a rock hard track setup, so I am not surprised the SS was quicker around a track.
04-01-2015, 07:19 PM | #130 | ||
Any SSV Redline owners have the time to let us know what the stock pressures are for the car (as per Holden) please?
Also, interestingly, I've noticed the SSV has a higher sidewall than the XR8 tyres.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
04-01-2015, 07:36 PM | #131 | ||
04-01-2015, 07:56 PM | #132 | ||
The Ssv redline is firm and direct...
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
04-01-2015, 07:59 PM | #133 | ||
Also, just went through the gear ratios on the SSV VS XR8. I can see why the Manual VS manual the SSV was slower. The Auto of the SSV is shorter than the XR8 and the taller XR8 Auto wouldnt be that great around a track even with the power advantage. Can keep it in the required rev range easier
04-01-2015, 08:03 PM | #134 | ||
04-01-2015, 08:12 PM | #135 | ||
Thank you for that!
Explains even more now. XR8 is 38F and 41R. Better for road use vs track use. It's starting to make more sense (for those who want to discuss it unbiased).
04-01-2015, 08:24 PM | #136 | |||
Long live the GT !
You make an interesting point though regarding what owners would change on their new cars and I would think warranty would be their number 1 concern when "modding" their car to improve performance. I just priced up a set of Michelin Pilot Super Sports for a 2014 XR8 and the total came to $1994 @ tyresales. The Walkinshaw 310 package (with full factory warranty) for the SSV puts you out of pocket $6,500, but I'll bet it still won't be as fast as the XR8 in a straight line but an absolute weapon on the track. Ultimately depends on what the customer is after and whether they have blue-blood coursing through their veins For me personally, if a tyre change still means the XR8 is slower than the SSV around a small track like Winton, then so be it, I still think it is the better all-round car.
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
04-01-2015, 08:28 PM | #137 | ||
Don't worry about the expensive stuff. Cheap set of Nitto Invo's (going on the GTF soon) will see the XR8 be a lot quicker for around $1200
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue Last edited by kypez; 04-01-2015 at 08:50 PM. |
04-01-2015, 08:49 PM | #138 | ||
I get all that re replacement tyres, I really do. All I am saying is these comparisons are between new stock factory vehicles, so these comparisons will always be with the tyres they leave the factory with.
A review of second hand vehicles is more difficult as then it is as you say - the cars will have whatever tyres have been thrown at them by their owner, as evidenced by the couple of posts above talking of Nittos in one and Michelins in the other. Comparison between new cars but with their stock tyres replaced by aftermarket - you'll end up in a tyre test to determine which brand to go with rather than a vehicle test. Even then, couple of posters have already said different tyres suit different cars/drivers - what if the tyres that suit the Commodore do not suit the Falcon (or vice versa)? You could test them using the same tyres but one car could still be disadvantaged by the tyre selection. Put on whatever tyres suit each car best and then you will still have complaints that one car had better rubber than the other, even though both had the best tyres available in whatever category your new car different tyres test permits. So just seems easier to test them with the tyres they come with - the tyres that would be on it if you buy it. That way someone could actually get something out of the review in terms of a car's grip etc, rather than learn how the new car would perform on a select set of tyres that it is not sold with and ultimately might not be their choice for replacement tyres when the time comes. |
04-01-2015, 08:53 PM | #139 | |||
But I still think the problem is the pressures...
04-01-2015, 08:59 PM | #140 | ||
"Final 8"
Ok, next observation, are the tyres manufactured to a specification from Ford or Holden, or are they an off the shelf item, and what other components in these cars are off the shelf items v's manufacturers specifications?
04-01-2015, 09:05 PM | #141 | ||
Car tragic
Probably a bit of both. But as I won't be circuit racing my streeter I won't feel cheated when hear the supercharger whine, hear the crackle over 3K RPM and compare the underbonnet areas to GM guys with TMNT backs on show.
04-01-2015, 09:26 PM | #142 | |||
Stop clutching at straws.. Xr8 better far better for outright grunt. Ssv far better chassis balance and cornering You can throw any tyres you want at that xr8 and it won't be better than that ssv |
04-01-2015, 09:57 PM | #143 | ||
"Final 8"
I know I'm new here, and don't want to step on toes but OMG, this is ridiculous, saying one is far better than the other at either discipline is madness. How many tracks do people drive on, on their way to work etc etc...Surely we can accept that both (all) cars are great value for money, and something that we are all gonna miss. I think there is more than one camp on here clutching at straws as well
04-01-2015, 10:53 PM | #144 | |||
As I've said, was quicker in the GT (very similar to the XR8) than SSV... I know whose "testing" I'll go with.
04-01-2015, 11:59 PM | #145 | |||
BLUE OVAL INC.
Honestly, the crap thrown around by some supporters is bloody embarrassing to say the least. Let me get this right. We've blamed the bloke behind the wheel. We've blamed the track layout. We've blamed the tyres. We've blamed the tyre pressures. All we're missing is for someone to tell us how the XR8 wins morally because Holden wasted more money... |
05-01-2015, 12:17 AM | #146 | |||
Soooo in come the professionals and prove that these clowns can't be trusted one bit, even with these simple stock oem equipped cars. As the FORD wiped the floor with its most powerful ever Aussie car title I take these Holden biased test with a grain of salt knowing full well money rules the world.....Holden is the big dog around here and would never rule out anything sly going on to benifit the holdens. |
6 users like this post: |
05-01-2015, 12:47 AM | #147 | |||
3 users like this post: |
05-01-2015, 12:53 AM | #148 | |||
The quality of posts here is appalling. If you don't track cars, you won't get it. All I'm looking for is a balanced argument with manual cars! I'll concede the auto ssv might be quicker than the auto XR8, but till I see a manual against manual, I'm not jumping on the bandwagon just yet. Especially not with my own experience that says otherwise!
05-01-2015, 01:41 AM | #150 | ||
BA/F6 BF/F6 SSV/R TTG
True about the most powerful Aussie car. BUT what do you think HSV will do with the last GTS
Ford and FPV have fired their shots. I bet holden and HSV up power enough to go out on top And they easily can as the car is engineered to handle the extra power
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
