Old 13-09-2016, 08:25 PM   #121
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Definitive au2-au3 brake upgrade thread
Originally Posted by XF_Pilot View Post
Standard AU or BF? Do they need to be slightly longer?
Sorry Standard AU
UK
Old 15-09-2016, 08:18 PM   #122
XF_Pilot
Default Re: Definitive au2-au3 brake upgrade thread
Ok thank you. I can get a set custom made. Would you suggest the standard AU ones lengthened slightly? If so by how much? Are we talking IRS or beam here too?
XF_Pilot is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2016, 11:48 PM   #123
XF_Pilot
Ok guys. I have started the conversion and started to tackle the rears tonight.
The catch is, that I got these calipers in a box so ibdont know which is left and which is right.
Can someone please confirm if, when the BF rear caliper installed in the car, brake line should be above or below the bleed nipple? This will confirm orienation for me.
Any tricks to getting the front left and right confirmed?
Thanks?
Old 21-10-2016, 11:56 PM   #124
ebxr82nv
Common sense would suggest the nipple should be at the top but they do weird **** on Falcons that makes no sense at all.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2016, 12:05 AM   #125
XF_Pilot
This is also a live rear axle if that's worth anything. Can anyone who has done the conversion confirm which brake lines they used on the rear (live axle)
Old 22-10-2016, 01:18 AM   #126
Tiger57
Just checked a picture of mine and the bleeding nipple is above the brake hose. I also used the standard AU brake lines front and rear.
Tiger57 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2016, 08:53 AM   #127
XF_Pilot
Thank you! Is yours a live rear end or IRS?
Old 22-10-2016, 11:06 AM   #128
Tiger57
Mine's a live rear end
Old 23-10-2016, 12:12 AM   #129
XF_Pilot
That's great, thank you for that. I thought I might have yobuse BA lines because the AU ones looked short but obviously not. How did you find the upgrade? Thanks!
Old 23-10-2016, 01:07 PM   #130
Tiger57
I just bought some Braided Lines of eBay recently and they were to suit the standard AU calipers. The conversion is well worth it. I punish my brakes through the hills and I haven't suffered any brake fade yet.
Old 24-10-2016, 07:36 PM   #131
inventiv
inventiv's Avatar
Anyone looking for a massive upgrade on the AU Brake Setup should check out the for sale thread now - have a sweet BF Turbo Premium Brake upgrade for sale on the bay.
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2016, 01:17 AM   #132
XF_Pilot
Thanks guys!
One last thing. do the BF turbo Rear brakes have the Philips head securing screw in them? The rear rotors that I have don't have any provision for them? The AU ones that I just removed did.
Old 26-10-2016, 01:46 AM   #133
tkfd
tkfd's Avatar
No the larger rotors don't have them. Mine, I just drilled them out using old AU ones as the template. Remember you will need to countersunk them to accept the grub screw.
tkfd is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2016, 09:52 AM   #134
XF_Pilot
Ah that makes sense then. I was starting to think that I had been given the wrong rotors.
I guess it's worth doing? Do the BF+ have a different retaining system or just taken care of by wheel nuts?
Old 26-10-2016, 10:49 AM   #135
Sox
RIP...
Sox's Avatar
The screw isn't needed.
Oval Everywhere...
Old 26-10-2016, 11:37 AM   #136
tkfd
tkfd's Avatar
not really needed, but I use it as it keeps the rotor in place when changing pads and adjusting handbrake. Up to you I guess.
Old 21-06-2017, 12:54 AM   #137
jfk069
New Guy
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Hey guys,
Just in the planning stages to do this upgrade to my EF sedan as the front brakes are average and are constantly warping.
Just wondering if this upgrade changes the front wheel offset to the post AUII offset.
If so, will fitting BA brake on the rear change the offset to post AU2 offset for the rear.
Thanks in advance
jfk069 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 09:30 PM   #138
auxlr8
Hi guys. Can some one please send me a link to the definitive au 1 brake upgrade thread. I just can't seem to actually find it. Thanks
auxlr8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 11:32 PM   #139
tkfd
tkfd's Avatar
Cool Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Is this it?
https://fordforums.com.au/showthread.php?t=11263967
Yes that's it, view in Chrome to see picks.
UK
Old 20-09-2017, 02:40 PM   #140
auxlr8
Thanks mate, cant get the pictures to work but the write up is excellent anyway. Just to make sure i got everything i need was it.....
au3 uprights
au3 lower control arms with spindles and hubs
au3 front brake lines
au3 front sway bar, mounts and clips
4x8mm-100mm bolts with washers and nylon nuts
au3 braker booster
au3 brake master cylinder
bf front brake callipers
$275 from the wreckers
bf 322mm brake upgrade caliper supports from ebay
bf 322mm discs
pads
$250 from ebay
dot 4 brake fluid
Thats everything for the front i need?
Also, what options are out there for upgrading the rear brakes on an au1 5.0 v8 fairmont ghia with irs?
Thanks guys for ur help and info
Old 07-10-2017, 03:37 PM   #141
JC
JC's Avatar
Thumbs down Re: Definitive AU1 to AU2/AU3 brake upgrade thread
au3 uprights
au3 braker booster
bf 322mm discs
pads
$250 from ebay
dot 4 brake fluid
BF XR6T or territory rears (328mm disc) are a good upgrade on the rear. You just need to make a 3mm spacer to mount the rear caliper (it goes between the caliper and the hub mount) - everything else just bolts up. You will need factory 17s minimum to clear these brakes.
Ford Performance Club ACT
Old 23-10-2017, 12:14 PM   #142
auxlr8
So I've got everything i need together for the upgrade. Decided to go braided lines front and rear instead of changing the booster and master cylinder. My questions is; If I'm putting an au3 front end on my au1 with bf calipers the correct brake lines are au3? Also if I'm putting rear ba brake calipers with spacers do i need ba rear lines or standard au 1 lines and do i use my existing au1 bolts for the calipers or do I need the ba bolts? Just want to make sure i order the correct braided lines.
Thankyou
Old 23-10-2017, 12:17 PM   #143
tkfd
tkfd's Avatar
I got custom braided for the rears. AU2/3 fronts you'll be fine.
Old 23-10-2017, 12:39 PM   #144
auxlr8
Unfortunately there's no one where I live who can custom make the lines so i have to order from safe brake online, that's why i was hoping for a definite answer on if I need standard au1 irs rear lines or if i need ba rear lines to match the ba calipers?
Thanks again
Old 23-10-2017, 12:43 PM   #145
tkfd
tkfd's Avatar
Give them a call. SafeBrake are pretty good with replies, in fact I think they may have lines for this conversion. Its not so much the lengths, its the connections that are different A series to B series, if I can remember.
Old 23-10-2017, 12:45 PM   #146
auxlr8
Ahh, ok, make sense. Thanks for the advice
Old 23-10-2017, 03:02 PM   #147
auxlr8
I got a reply from safe brake stating they dont do a line from au irs to a ba caliper so can anyone please confirm that au irs rear braided or standard brake lines for that matter will bold to the ba caliper?
Old 23-10-2017, 03:25 PM   #148
PG2
#neuteredlyfe
PG2's Avatar
Yes, you can use the brake lines that are already there (or get some braided brake lines).
When I changed my rear brakes to 303mm I didn't even disconnect the rear calipers.
PG2 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2017, 03:44 PM   #149
auxlr8
Thanks for your reply. When you say u didn't even disconnect the rear caliper, how did that work? Standard ford au irs is a solid 287 mm disc and single piston caliper. The ba rotor is 302 mm ventilated and the ba rear caliper is twin piston from what i understand. Either way thanks for clarifying that the standard/braided au irs rear lines will attach to the ba caliper. My apologies for the extensive questions, just getting my head 100% before the job is tackled.
Old 23-10-2017, 03:49 PM   #150
tkfd
tkfd's Avatar
The BA is still only a single aswell, but larger piston and pad area, plus of course larger rotor to suit.
Don't know what PG2 means either ? But aren't you changing to the 328mm rear rotor (territory/BFGT)
