View Poll Results: Did Ford use the correct Sequential Shift direction? | |||
Yes - I think the Ford direction is correct | 205 | 74.28% | |
No - I think they should reverse | 57 | 20.65% | |
Candy | 14 | 5.07% | |
Voters: 276. You may not vote on this poll |
28-03-2006, 06:59 PM | #91 | |||
Flat floor shifter
Fair enough but fords way is made for premature ejaculaters. G forces start , man trys to hold back but is forced into changing early as he's bucked back into his seat holding on tightly to gear stick. All he's left with is a hand full of gears and no cigar!!! : |
28-03-2006, 07:27 PM | #92 | |||
...fairly odd
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
28-03-2006, 08:19 PM | #93 | ||||
Previously ScottishXC
Your trousers are muffling your voice.
Great transactions with the following members: BJ Gilesie XAGTCoupe Pilch Aussie_afroman Donut King Bad Boy Benny BAWITHLOT Greenmachine Pinkbits CUZ351 OhioXB Falconunbelievable 4VXC Uncleraggy FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project Quote:
28-03-2006, 08:30 PM | #94 | |||
28-03-2006, 08:31 PM | #95 | |||
28-03-2006, 08:35 PM | #96 | ||
Flat floor shifter
No l realy dont care which way it goes. It aint the manual gearbox that you auto owning guys try to make it out to be though. As dr phil said" you can stick feathers on a horse but that dont make it a chicken"
28-03-2006, 08:37 PM | #97 | |||
Flat floor shifter
28-03-2006, 08:43 PM | #98 | ||||
What it is, is a f##k sight better gearbox than your traditional automatic.(also an owner) Speak to Maserati if you want a true 6 speed manual that can also change gear for you...tres expensive and frankly, a little cumbersome!
28-03-2006, 08:56 PM | #99 | ||
Flat floor shifter
Your point taken. :
29-03-2006, 12:56 PM | #100 | |||
29-03-2006, 03:26 PM | #101 | |||
Adapt or perish...
And as I also said, the way Ford have configured sequential shift, should be an Australian Standard. That way, we won't have bits of Mitsubishi auto gearbox all over our roads... I'll shut up now.
Carless
05-04-2006, 10:54 AM | #102 | ||
PM me if you want
I think its more a hangover from day dot when cars got automatics, you always pulled it further back to select a lower gear P R N D 3 2 1 so habit is the reason I think people call it wrong, when the physics of forward momentum make sense to the way it has been setup. Breaking the years of habit and learning does take awhile.
06-04-2006, 09:28 PM | #103 | ||
had a good play around with my knob (shifter knob , ofcourse) today and on my NA XR6 the gear box will NOT downshift if a gear has been selected @ WOT , it will just slowly rev out - as it should.
James |
06-04-2006, 09:59 PM | #104 | ||||
I think that we established that it WILL a long time ago. The ONLY exception is if you have had an edit. Have a good look through the previous posts including the quote from the BA instruction manual. As I said before, it is for emergency reasons and you have to be driving the car F$%king hard in order to make it do so.
06-04-2006, 10:18 PM | #105 | |||
07-04-2006, 07:38 AM | #106 | |||
07-04-2006, 06:52 PM | #107 | |||
07-04-2006, 06:53 PM | #108 | |||
07-04-2006, 08:14 PM | #109 | ||
just think about the g force factor when u are up it and need to change u are being forced back hence it is easier to pull back when braking and need to cahnge down u are forced forward very simple and a good move by ford
08-04-2006, 12:03 PM | #110 | ||
Th 'G' force?????????
What car do you drive?
2007 BF Typhoon 11.79@117 |
17-05-2006, 04:49 PM | #111 | ||
Built Ford Tough
BMW does it the same way...
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
18-05-2006, 10:34 AM | #112 | ||
I dont think it really matters which way it is, but i do think there should be standard.
For road use either is fine, once you learn to use it, it feels natural. But if you are swapping between different cars with different systems its a pain (a bit like indicator stalks on some cars) I think the manufacturers should make a standard and follow it, one way or the other. |
18-05-2006, 02:58 PM | #113 | ||
Chairman & Administrator
After the T-Series steering wheel mounted buttons I always thought the BA was a step backwards in putting it back on the console. I understand that it was done to allow sufficient room in the steering column loom to put the audio controls back on the wheel but I didn't like it. Early cars had it the reverse way anyway.
Having used the SRT8 one for awhile now (which is left for down and right for up I prefer that method as it is far easier to use and requires less movement. Russ
Observatio Facta Rotae
18-05-2006, 03:33 PM | #114 | |||
Sometimes the BA Futura we had 02 and the XLS ute 05 both will kick back into DRIVE if your like in 4th at 50 and put it flat the floor, the D flashes on the dash when you do this.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25. |
18-05-2006, 05:24 PM | #115 | ||
Test drove a Legacy 3.0 R B-spec recently, which has the changes going the opposite way to the Falcon and quite frankly I didn't find it a problem, and I used to think the Falcon way was right.
So I've decided I couldn't care less which way they go sleep: |
20-05-2006, 05:40 AM | #116 | |||
Happy Volkswagen owner
If thats the way then yeh thats the way it shoud be. It's also the same in the SV6, if you have it in AS mode and pound it to the floor it won;t kick back till you tell it to, and thats the way it should be, after all, you are basically wanting a manual by pressing the AS button or shifting it accross. Stoney! |
21-05-2006, 05:15 PM | #117 | ||
Merry Xmas To All
Ford's way is good..... But I let a Commy driving mate drive once, and he kept going the wrong way... _
21-05-2006, 08:45 PM | #118 | ||
I wish it was reversed. But only because my XT ute runs a B&M quicksilver shifter which is the reverse of the XR8. The XT is less forgiving when shifting from 2nd to 1st at 5000...
22-05-2006, 07:17 AM | #119 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
04-07-2006, 06:50 AM | #120 | ||
Mr old phart
I had a mega shifter years ago. Went the wrong way a couple of times when I first got the BA. That said, I prefer the Ford shift direction now that I'm used to it.
An object at rest cannot be stopped!! BA GT-P Blueprint |
