#91 | ||
irregular member
The tolerances in these cars aren't that good to have identical 80-120km/h times in either Fords or Holdens.
There have always been cars screwed together a little better or worse than others. Pick another two Commodores and it could easily be the other way around. |
#92 | |||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
I did three brake tests in the FGX XR8 down Winton's straight a few weeks ago. From standing start to stop was doing 175kph. A couple of people saw 180kph. Given this was done without any corner exit speed 180+ should have been done easily by Tander. |
#93 | ||||
#94 | |||
Having (comparatively) insufficient grip stock is a lot like having (comparatively) insufficient power stock. Stock is stock. |
#95 | |||
MOTOR have been using the same Racelogic GPS timing gear that I have. It defaults to the nearest one hundredth of a second and when I've checked it's distance measurement on a number of occasions, it's been within 1/3 of one percent of the true distance. Also at WSID it's time measurement from 60 feet to the end of the quarter was within 1 hundredth of a second of the track timing (which shows times to the nearest thousandth of a second) in run 1, and in runs 2 and 3 it was around 3 hundredths of a second pessimistic, in other words the car was fractionally faster than the Performance Box said it was. I'd certainly expect their rolling 80 to 120 times to be either spot on, or no more than 1 or 2 hundredths on either side of the exact figure. |
#96 | |||
To me changing a tyre which is a consumable is not the same as changing an engine, but each to their own.
Previous Rides Bionic BA MKII XR6T 245kW I6 Turbo, 6spd Manual Grey (yuk what was I thinking) AH Astra CDX Coupe 93kW NA I4, 5spd Manual Sensation FG XR8 290kW NA V8, 6spd Automatic Current Rides Octane GTF SC V8, 6spd Manual, Manta 3" X pipes and hotdogs Starlight Lotus Evora S 258kW SC V6, 6spd Manual |
#97 | |||
Its like going out on the town and everything is closed for the night |
#98 | ||
Long live the GT !
How devastating for you !
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
#99 | |||
#100 | |||
Stock is stock mate too many variables otherwise |
#101 | |||
Edit: the guy buying the cams will be out 4k when he buys his replacement tyres, the guy only replacing his tyres is still only out 2k as well just FYI...
#102 | ||
irregular member
Only a couple of apex speeds mentioned.
Turn 4 apex speed: SSV-R - 88.14km/h SS - 85.93km/h XR6T - 84.68km/h XR8 - 84.40km/h Turn 9 apex speed: XR6T - 54.91km/h SS - 54.66km/h SSV-R - 54.50km/h XR8 - 52.96km/h |
#103 | |||
Long live the GT !
Like has been said, it's a consumable product like getting better brake pads or filling the tank with 100 octane. Comparing that to getting cams for an SSV is basically an aftermarket mod which boosts top end power but also voids your engine warranty in most cases.
#104 | ||
BA/F6 BF/F6 SSV/R TTG
More time is made up in the fast corners if a high corner speed can be maintained.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
#105 | |||
Suspension components wear out too - why not fit stickier tyres and also shockworks suspension and aftermarket bushes etc to further improve the performance and handling of the "stock" Falcon. Surely bushes are a consumable. Don't see anyone disputing XR8 is faster in a straight line - seems to be commonly accepted, and the timed runs support this. What appears to be in dispute is whether the Commodore is better when it comes to handling, braking, putting its power down, etc, which is what the lap times around Winton seem to indicate. Some seem to think it is purely a matter of tyres and would like a comparison where they both run the same tyres - but if the only "stock-maintaining-modification" was fitting better tyres to the Falcon wouldn't the Falcon then need to smash the Redline's laptime given its power advantage? Wouldn't the true test be same tyres and have them also run the same power too, so the only variables are suspension and chassis? Think I am starting to understand why Territory is a Falcon wagon but a Commodore ute is not a Commodore. Holden put better quality tyres on as stock items to improve handling and ability to put power down - it is one area they have an advantage. Why does that advantage need to be removed because Ford do not do the same even though they have every opportunity to? FPR had the wider R-Spec rear wheel tyre/package to improve over the 'standard' GT...if you wanted to compare the performance of a 'standard' GT to the performance of an R-Spec do you need to use same tyres on each? No, because the wider rears is one of the advantages that makes the R-Spec an R-Spec. Last edited by Iggle Piggle; 03-01-2015 at 09:32 PM. |
#106 | |||
Long live the GT !
Sure, suspension components wear out too but that usually takes a few years of heavy use, unlike tyres which can be "worn out" in 10min if the driver feels like doing an extended burnout. ![]() SSV has track ready suspension and tyres but lacks in the power dept while the XR8 has 500hp but lacks the grip to put that power to good use. If both cars had the same power output, tyre selection will have little effect on track times and cams would be the way to go. Bottom line is, the XR8 needs better rubber to reach it's true potential.
4 users like this post: |
#107 | ||
![]() Join Date: Jan 2005
The Dunlops on the GTF got to 46 PSI starting from 38 when cold at the North Circuit at SMP. Anyone who knows that track knows that thats a huge increase! I dropped them down to 39 PSI HOT and the car just transformed! I was 3 seconds a lap quicker! Thats a huge gain! Winton will see the tyre pressures get even higher! I wouldnt be surprised if the Dunlops got to close to 50 PSI after 2 laps. Would have handled like a dog!
I doubt the muppets doing these tests take the time to check these things. I didnt see it being done or mentioned in the other test.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
#108 | ||
To be fair though, they probably didn't check those things with the Holdens either...
#109 | ||
Yes, but the wrong pressures will affect the XR8 more with the higher weight and power and an already lesser tyre.
#111 | ||
Sure... I prefer the girl who's hard to get rather than the town bicycle...
#112 | |||
Au Falcon = Mr Reliable
![]() Ford really should've put better tires on the last XR8, no if's or but's hey! cheer's, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 03-01-2015 at 11:29 PM. |
#113 | ||
Now Fordless
Would be interesting to see how both cars performed if you swapped engines. Could the VF handle the same with more weight in the front and faster entry speeds?
#114 | ||
Touche', but they're as easy as each other to get, just that one's high maintenance once she's pulled you in...The other is easy to live with, isn't needy and doesn't require your full attention to make the relationship work. High maintenance chicks ain't worth the hassle most of the time.
#115 | |||
#117 | ||
The high maintenance ones almost always look better too ;)
That's why they're high maintenance.
#118 | ||
Well, you cant not have something special about you and be high maintenance!
#119 | ||
When the tyres on a press car are shagged, why do they fit a new set of the OEM tyres? Why don't they fit stickier tyres before handing the cars back to the press for evaluations of stock performance?
I know tyres are consumable and can be replaced with whatever suits the owner, but why are we assuming the owner of the Falcon stumps up more coin for some decent quality tyres? Why don't we assume he/she is a tight **** who replaces their OEM Dunlops with the cheapest tyres they can get off eBay that have a tread pattern shaped like chicken-in-a-biscuit? Or would it be best if we assume the Ford guy fits Nittos and the Holden guy fits retreads? We don't know who will fit what to which car for whatever reason in the future, so maybe the easiest way is to continue to compare the cars in stock factory trim. I agree tyres are consumable and are an easy fix - but isn't that the point, that some feel they need to "fix" the stock grip levels of the XR8 (just as some feel they need to "fix" the stock power output of their SS/SSV/Redline)? Some things might be easier to "fix" than others, but is that justification to change OEM equipment on only one vehicle to address its (perceived) shortcomings while leaving the other completely stock? For the record, I don't think the Redline is slow but I don't think it has the straight line speed of the XR8. Likewise, I don't think the XR8 is an ill-handling no brakes bucket, but I don't think it handles or brakes as good as the Redline. Just because each car has shortcomings when compared to the other does not mean each car sucks in that area - it just means the other car does that particular thing better. Something that is great is great...compare it to something that is exceptional and it will lose the comparison, but that does not mean it is no longer great. Last edited by Iggle Piggle; 04-01-2015 at 11:04 AM. |
#120 | ||
Research the GTS. It can more than handle the extra grunt and perform likewise. I assume the 6.2L blown GM V8 engine is heavier than Fords possibly as well.
