#61 | |||
What is strawman? JMM = good quality, guaranteed off the shelf drive in out package but expensive. wade, pacies combo = lots cheaper, maybe 10-20 rwkw short of JMM package. Turbo > NA packages. /end of story
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#62 | ||
Last warning
i wouldn't say garenteed package... we've seen on here alone that there have been people not pulling whats expected (on the JMM dyno), yes JMM are trying to fix those problems (good for those customers) but that by no means is garenteed, especially if you're interstate.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#63 | |||||||||||
E-Series Owners Club
Your ute is making decent power. You purchased all of your components as a package deal, and as such had no real idea as to what you were getting. You purchased your parts based on a power figure, not their specifications. You may have had experience building other engines, but as Brenden Mock used to say a lot (on the old forums) "many of the cams that work on other engines, don't seem to work on the I6". Quote:
#64 | |||
RIP...
Rick.
. Oval Everywhere... |
#65 | ||
Yeah but what is strawman? :(
#66 | ||||||
You're right, perhaps different plugs can allow me to run more timing and get more power. But that does not alter the fact that decent power can be made without running anything other than standard spark plugs. Quote:
What seems to be happening, is when people start to discuss the alternatives, you seem to have the need to shoot them down. Quote:
Dyno numbers are a somewhat debatable issue. Just ask any of the people who have run their cars at one of our dyno days, and NOT one of them got within 10rwkw (some where even further away) from the JMM figure. |
#67 | ||
Back to the topic, I'd say go a Dev3HL, manual, then just fork out for a chip as well. You should be pulling huge numbers then, and it will keep you satisified for a while.
Also take into account insurance. I don't reckon insurance companies are too keen on their clients having gearboxes that didn't come with the car from the factory. Also re-sale value on your car. A manual conversion on a car, that had an auto isn't that appealing to buyers. Maybe you should just get a Dev3Hl, on your auto. And save your money to do mods to your next manual car. My 2c
AUIII Falcon Forte, with SIX Appeal |
#68 | ||||||||||||||
RIP...
detonation is caused by many different reasons, different grind cams require different timing curves. All engine combinations have an 'ideal' advance curve where optimum power is achieved. If you're falling short of that optimum curve, power is reduced, and the only reason why you may fall short of that optimum curve is because of detonation. If a given spark plug will allow 2 degrees more advance, you have more power, simple. Do some homework on 'dynamic compression ratio' and 'static compression ratio'. Quote:
Wade would obviously recommend a cam which is similar to a DEV3 cam considering there is no head work and no heavy duty valve springs. Correct? Naturally a DEV3HL cam in this instance will produce more power, purely and simply because of it's higher lift. Quote:
The fact that JMM charge more for there $16 pipe is because unlike you or me, they have rent to pay, wages to pay, and many other expenses which go with running a business. As I've said many times over, every time this silly debate comes up, for some people a Wade/Pacemaker (or any other name you desire) concoction is ideal, however for the person who isn't handy with the spanners, or just couldn't be bothered racing around to different places selecting the parts, getting quotes to have it fitted, and then not having any kind of guarantee whatsoever that it will work, JMM is ideal. Are you just starting to see even a tiny bit of my point yet? Rick.
. Oval Everywhere... Last edited by Sox; 25-02-2005 at 06:10 PM. |
#69 | |||
RIP...
http://www.nizkor.org/features/fallacies/straw-man.html Rick.
#70 | ||
Lovin the Manual.
=\ geez
#71 | ||
Stockstandard: And I bet there are wades out there that can beat yours. Did these cars have all the other stuff making it an apples to apples comparison?
And I've yet to come across one that does, yes they had head work and extractors. Stockstandard: So you are saying coz your mate went cheap and did no research that it doesnt work? What I'm saying cutting corners does not give good results. Stockstandard:What is being suggested is that if you do your research you can get the same results for less money and learn a lot about your car. It is possible but not likely and doesn't always work out cheaper. Stockstandard: BTW: 134rwkw is a good result. Not for the money that was spent on it and the headaches caused. Neil Last edited by neil101; 25-02-2005 at 06:25 PM. |
#72 | |||
Last warning
and you don't learn about your car? even run the 1/4? i think thats a much better indication then just saying u've beat so many wade cam'd cars.. give us a time and we can talk :P
#73 | ||||||||
RIP...
He asked about a particular product, and sure enough (starting with post 5) all and sundry start on about how much better value other products are. Quote:
Not fair play IMO. Quote:
I've seen enough results and figures to know what works and what doesn't. Rick.
#74 | ||
I didn't say that at all!
You can only learn if your prepared to learn. I'd be happy to show how a falcon should go ![]() Neil |
#75 | |||||||||||
Do some homework on 'dynamic compression ratio' and 'static compression ratio'.[/QUOTE] I know the difference between dynamic and static compression, but as said earlier, we are not talking really wild cams here. Quote:
I'll bet you have no idea, considering i had to tell you just the other day. Quote:
Do you know ANY of the above specs? What about the valve spring specs i mentioned earlier? What specs do you know, exactly, given that you already said you don't know the cam specs??? Quote:
I dunno about you, but i'm not here to pay JMM's rent. I am going to tell people how they can do it themselves, if they don't have the inclination, then that is their choice. BUT i feel they should be informed. Quote:
JMM gear is good for someone who can't/won't do the work themselves. However, these people have the right to know of the alternatives before they make their decision. If they choose to go to JMM then that is their right. I see your point, however, in this case, it seems like you are the one trying to knock the alternatives, not us who are knocking the JMM gear. |
#76 | |||||||
#77 | ||||
"If valve springs are not needed, then it won't make as much power as a DEV3HL" Then I said "Regarding this whole "egg on face issue", your statement was that because the wade did not require valve springs the dev3 would make more power. IMHO this statement, while quite possibly correct, is making assumptions about the cam profiles that we dont know about. As I read it, it certainly implies the message that the cam with the biggest lift makes the most power. Since not all other factors about the cams are equal the statement is pretty meaningless. Lets just move on." How the hell does this make me a "strawman". It makes me wonder if we are reading the same thread here.
#78 | ||||||||
The point in going over old ground is because we have new members all the time, and we want people to be informed rather than just blindly buy because they don't have all the facts. We are here to share our experiences. Quote:
Do YOU? What's that - NO? Oh, seems like i have more facts that some people around here would think. :P Quote:
Oh, that's right, there was nothing to work out, because the car acheived perfect power figures on the JMM DYNO! |
#79 | |||||||||||||
RIP...
Do you have any idea on the effects on too little timing? BTW, it matters not how wild the cams are, timing is still extremelely important for an efficient engine. Your logic about timing is terribly flawed. Quote:
I don't believe that you do fully understand the relationship between static C/R and dynamic C/R. Quote:
You do realise you've had a hand in paying Autobarns rent, the pipe manufactures rent, Wades rent, Pacemakers rent, gee, every single item you purchase is paying for somebodies rent, putting food on the table for them, paying for the kids pushbike.... I can't believe I'm even saying this, you have no idea how business works. Quote:
Rick.
#80 | |||||||||
RIP...
And before you even go to the JMM dyno reads high garbage, I remember a thread on the old forums where a member had his car on the JMM dyno and another highly respected Vic based dyno, and the results were identical. All of my figures have also come up within 5% of of the JMM dyno (on 2 different dynos in Sydney). Many dynos do read different though, live with it. Rick.
#81 | ||
Yay, another day, another bullshit JMM debate that proves nothing.
#82 | |||||||||||
And yes, i do know exactly how business works. I have my own business. :P Quote:
What i said is that you don't HAVE to advance your timing to the Nth degree in order to get power. Yes you can gain power that way, BUT YOU DON'T HAVE TO! Quote:
#83 | ||||||||
Who the hell are you to make the decision for him? Quote:
However, many stock cars were pulling around the 100-110rwkw mark, which seems spot on to me. But what is also just as likely is that the JMM dyno over-reads... How can you claim that this is 'dyno proven'?? Sounds like nothing has been proven to me! |
#84 | ||
Stockstandard:You are the only one who is talking about cutting courners here by bringing up an example of what not to do. It has nothing to do with what we are all talking about.
I don't cut corners, It has been said why do you want to pay top dollar when you can do it cheaper, I was giving an example of what can happen and it has everthing to do with whats being said here, Bozza17 has asked for advice he has said he's not mechanically minded. Stockstandard:hmm, ok. How is it not likely? If I call wade, crow, and surecam and talk to all of them about profiles for a particular engine configuration, then read everything I can on the forums, how likely do you think it is Ill end up with a cam that doesnt work? So what your saying is just throw a cam in and she'll be right, To get an engine to perform at it's peak for maximum performance it all has to be matched, and I'm sorry paceys just don't cut it,genies are much better if you just want to get a good off the shelf item they do work well with most cams and give good results I have found. And as I've found time and time again wade,crow,camtech and surecam when I've spoken to them they have said to me can't garentee idle quality without a chip this is for a cam with decent lift that will make a difference with head mods. JJM stuff does has a lope yes but doesn't cut out at lights or hunt and fuel up while idling. I'm over this debate I found JJM stuff to work as a package goes it's pretty good from a driveablity point of veiw, Not saying other idea's won't work and wouldn't be cheaper but I've seen it too many times where it ends in tears. Neil |
#85 | ||||||
Do you have anything usefull to add, something you can back up perhaps?
#86 | ||
Can i ask what you do for a living to back up your theorys?
Neil |
#87 | ||
Is a saloon car a street car I think not.
Neil |
#88 | ||
Having used pacys on my car I can say they didn't work gained nothing over stock on the dyno.
Neil |
#89 | |||
I would also like to see the dyno results and tests you have conducted to state that pacemakers don't cut it. A huge number of falcons run them, including race cars and get great results. Unless you post these details with comments like that it weakens your whole argument. |
#90 | ||||
Maybe my ideas come from experience - talking to a lot of performance engine builders (including JMM), doing my own research (reading almost every post on these forums for the past couple of years), and building my own engine.
